Thread started 31 Mar 2008 (Monday) 09:47
Head or no head on a monopod?
bbbig
Mar 31, 2008 09:47 |  #1
Are you finding it useful to have a tilt/swivel head on your monopod? Do you use your monopod attached directly onto your camera? Other than for having a quick-release system on my monopod's head, I never found the need for tilt/swivel.
Your thoughts?
Roy
5D Mark III (external link) | 24-70 2.8L | 70-200 2.8L IS | 50 1.2L (external link) (full gear list)
Jon
Joined Jun 2004
Mar 31, 2008 09:54 |  #2
If you always shoot "straight and level" and only with lenses which have a tripod mounting ring, then you probably don't need a head on a monopod. If, like me, you're likely to shoot with the lens at other than right angles to the tripod, or using lenses which don't have tripod mounting rings, it's a different story. I use a Manfrotto 486RC2 so I have flexibility in my camera orientation independent of where the monopod rests.
Jon
Cocker Spaniels
donaldjl
Mar 31, 2008 10:10 as a reply to  @ Jon's post |  #3
IMO, one of the big advantages to a head on a monopod is the ability to use quick release plates and not have to screw the monopod into and out of the camera on a frequent basis.
Personally, I've been quite happy with the Manny 3229 swivel head, but I likely don't have some of the shooting position demands that require or would be simplified with a small ballhead.
"And when he came to the place where the Wild Things are they roared their terrible roars and gnashed their terrible teeth and rolled their terrible eyes and showed their terrible claws..."
440roadrunner
Mar 31, 2008 11:45 as a reply to  @ donaldjl's post |  #4
I built a monopod, and ended up with a Bogen 3229 tilt head. Not only does it allow me to quickly kick the monopod out, such as for bracing against a tree, but I can fold the head and monopod clear back behind the camera, and use it as a "shoulder fired" device. It really works out great for me.
2-40D's, 30D, Xt, EOS-3, Elan7, ElanII 100-400L, 24-105L, 17-55IS 2.8, Sig 12-24 EX DG 4.5
Mamiya M645 1000S, 45mm 2.8, 80mm 1.9, 110mm 2.8 + 2x extender
PacAce
Joined Feb 2003
Mar 31, 2008 11:46 |  #5
donaldjl wrote in post #5230151 (external link)
Some QR systems allow you to screw the QR clamp (or base) directly on the monopod without the head if all you're after is a quick way to mount and unmount a camera or a lens.
...Leo
argyle
Mar 31, 2008 11:58 |  #6
You don't necessarily need a ballhead to utilize a QR setup. I have a 3232 mounted on my monopod, with a Markins QR screw clamp attached directly to the 3232. And if I didn't have the swivel head, the clamp would screw directly to the monopod post.
bbbig
Mar 31, 2008 12:00 |  #7
440roadrunner wrote in post #5230727 (external link)
Sorry off topic - I had heard of this "over the shoulder" technique before, but I have a hard time visualizing it. i.e. I can't see how you can get the monopod _over the shoulder_ - then your camera will be still way too high for your eye to reach?? Pictures anyone?
Roy
malla1962
Joined Jul 2004
Mar 31, 2008 12:45 as a reply to  @ bbbig's post |  #8
No head on my mono, I am just going to put a QR clamp on it.:D
Balliolman
Mar 31, 2008 12:49 |  #9
Ballhead. Admittedly it was a fiddle at first getting used to the monopod-ballhead combination. Now accustomed to the gear I find it an easy combination to use.
Balliolman
Stereoshooter
http://www.flickr.com/​photos/balliolman/ (external link)
Want to know more? Q. & A. with Balliolman: 3D/Stereo Photography https://photography-on-the.net/forum/showthre​ad.php?t=150661
DReb; Canon 50 f1.8; Canon 28-135 IS; Loreo LIAC(T); Flashtrax; Canon 17-40 L; Manfrotto 055 PRO B tripod; Canon 28mm 2.8; Whibal
Need: Primes; Would like: Canon 5D;
HankScorpio
Mar 31, 2008 13:20 as a reply to  @ Balliolman's post |  #10
I have a head on mine as it's the only way I can the the camera into portrait orientation.
My collection of boxes with holes (external link)
EXIF semper intacta.
Gort! Klaatu barada nikto.
bbbig
Mar 31, 2008 13:27 |  #11
HankScorpio wrote in post #5231348 (external link)
Ah, that does make sense!
Roy
SkipD
Joined Dec 2002
Mar 31, 2008 13:29 |  #12
I also use a Manfrotto 486RC2 ball head on my monopod (a Manfrotto 680B), and the ball head provides me with a tremendous amount of versatility in how I can use the monopod over either no head or the one-way tilt head.
Skip Douglas
MT ­ Stringer
Mar 31, 2008 13:33 |  #13
I haven't tried a ball head on my monopod, a Manfrotto 679B. Camera and lens weigh about 10# and the pod is mounted to the lens ring mount. I guess I figured a ball head would be more trouble than it is worth. I just bought a ball head, so I may try it out. Mostly, I just need the pod to support the weight.
Mike
MaxPreps Profile (external link)
My Gear List
Bumgardnern
Mar 31, 2008 17:52 |  #14
I use a Manfrotto 486RC2 on my monopod and love it. When I first got a monopod I tried using it with out a ball head and did not like it. For me the ball head made a huge difference in its usability.
donaldjl
Mar 31, 2008 20:19 as a reply to  @ Bumgardnern's post |  #15
I guess I wasn't as clear as I should have been, but several have alluded to my point that it's advantageous to be able to use quick releases on monopods. It really comes down to your own needs.
13,223 views & 0 likes for this thread
Latest registered member is ruslan1
1891 guests, 324 members online
