Thread started 01 Apr 2008 (Tuesday) 02:55
Wake Boarding Shoot Help
ChadAndreo
Apr 01, 2008 02:55 |  #1
A friend of mine just asked me to shoot him and his cousin wake boarding mostly because he wants action shots of his cousin doing back flips.
Right now I have a 30D with only have a 50mm, but I might have access to a 75-300mm lens.
Could anyone give me any advice at all especially with the camera settings?
I was also wondering if it would be a good idea to use burst?
Photographer + Cinematographer
LETS CONNECT - SOCIAL PHOTOGRAPHY SITE LINKS | Website (external link) | Wedding Site (external link) |
| Flickr  (external link) | Gear | 500px  (external link) | Tumblr (external link)
Aaagogo
Apr 01, 2008 03:04 |  #2
i used to wakeboard,
i would say fast shutter speed's, boat's moving, person is moving, alot of moving,
i think the 75-300 tracks a little slow for jumps, but if the person is staying rather still, i think should be ok.
burst is only usefully when you can get a good lock and focused shots.
just thinking out loud.
https://photography-on-the.net …p?p=4655753&pos​tcount=953 Your 1st 10,000 images are your worst
One photo out of focus is a mistake, ten photo out of focus are an experimentation, one hundred photo out of focus are a style
ngorkngork
Apr 01, 2008 03:49 |  #3
I was able to try shooting wakeboarders at CWC in Cam Sur Philippines last January, and most of the time I tried the fastest shutter speed I can get with the max aperture of my kit lens at max zoom of 85. I'm also usgin high iso. Try getting close to the subject if possible without endangering your gear. I saw somebody using the nifty-fifty. But generally I'm not happy with my try so If I have a chance to get back there, I'd make sure I'll bring a faster lens.
Chandler.
Apr 01, 2008 04:31 |  #4
The great thing about shooting wakeboarding from a boat is that the wakeboarder is always about the same distance from you. I use my 70-200 on a rebel XT, and it's the perfect lens for the job. The 70-300 should do well. I set the aperture at around f/5.6 in Av, open up 2/3 stop and I don't really have to worry about focusing. Keep in mind this is only true If you are sitting near the spot where the rope is connected.
If you want the very best action shots, you should rent an underwater housing and sit on an innertube that has a shorter rope than the wakeboarder's. From there, you can shoot up at them with a wide angle lens. Usually only photographers that are shooting for magazines do this.
I don't have any shots on this computer of backflips, but I do have these watersports shots:
There are no rules for good photographs, there are only good photographs. ~ Ansel Adams
mikeb540
Apr 01, 2008 23:52 as a reply to  @ Chandler.'s post |  #5
i would think once your focused on the boarder, you wouldnt have to change it much since there on the end of a rope .. the distance to the suject wont be changing much.. just an idea tho
mike
Canon Rebel XTi
Canon 28-105mm USM
Sigma 10-20mm
my Work: http://www.outdoorvent​uresschwinn.com/ (external link)
Photo Gallery: www.mbphotos.exposurem​anager.com (external link)
Aaagogo
Apr 02, 2008 01:16 |  #6
just tossing it out there,
he's leaning back too much and putting too much weight on his back leg. the board should be flatter to the water and his back knees less bent, that will take most of the weight off the back of the board.
He should be almost close to the standing position ;)
Chandler. wrote in post #5236272 (external link)
Chandler.
Apr 02, 2008 01:25 |  #7
Aaagogo wrote in post #5243020 (external link)
That was his very first time wakeboarding. He did quite well.
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Apr 02, 2008 09:48 |  #8
Try manual in those tough conditions. First set the f-stop & shutter speed you need. Then adjust the ISO. Need an exposure crutch?
More on how the subject affects the exposure in Post # 47
Chandler.
Apr 02, 2008 10:35 |  #9
Good call Frank. I'd definitely use manual now that I know how it works (thanks to your threads).
allstar25
Apr 02, 2008 13:18 |  #10
Chandler... that 2nd pic is hot!
I'm 16 . . . Give Me a Break
Chandler.
Apr 02, 2008 15:08 |  #11
Thanks allstar. :) The conditions were far from hot though. air temp in the low 40's, water temp in the low 50's. This was just after thanksgiving, near Seattle.
Dianne ­ Dela ­ Merced
Apr 03, 2008 02:10 as a reply to  @ Chandler.'s post |  #12
I want an effect wherein the background is blurred and the only clear shot is the one you're focusing...how do you do it in a fast paced environment... :confused:
He who is afraid of asking is ashamed of learning
[Wakeboard (external link)] [Serious Wakeboard (external link)]
PhotosGuy
Joined Feb 2004
Apr 03, 2008 09:36 |  #13
The longer the focal length of your lens, the faster it is (f-stop, use it wide open), & the closer the subject is to you, the better the effect will be.
Apr 09, 2008 01:17 as a reply to  @ PhotosGuy's post |  #14
Thanks a lot for your help...
1,348 views & 0 likes for this thread, 8 members have posted to it.
2767 guests, 176 members online
