Thread started 01 Apr 2008 (Tuesday) 20:05
Skyport transmitter, pc port or hotshoe?
Aszental
Apr 01, 2008 20:05 |  #1
Hey just a quick question.
Got my skyports a few weeks ago and been playing around with them.
I tried putting the skyport in the hotshoe but it wouldnt fire the flash, so i connected the pc port to my camera and everything worked fine.
I thought this was the way they were supposed to work, but after reading something online im under the impression it should be working from the hotshoe alone?
is that correct?
thanks
Website (external link)
FlashZebra
This space available
Apr 01, 2008 21:20 |  #2
If you camera has a hotshoe you should get function without needing to connect a sync cord to the camera's PC port.
I have seen this issue on a couple of other web posts.
Give the hotshoe and the foot on the Skyport a nice brisk rubbing with a clean cloth.
If that does not fix it I would contact Elinchrom for a replacement or a repair.
Enjoy! Lon
dragulaz
Apr 01, 2008 21:45 as a reply to  @ FlashZebra's post |  #3
Yup, sounds like a defective unit or dirty contacts. Mine works just fine on hotshoe.
Bret
Canon EOS 5D, various lenses, Elinchrom studio lighting, and other "goodies"
Aszental
Apr 01, 2008 22:20 |  #4
FlashZebra wrote in post #5241720 (external link)
thanks guys, problem is ordered them from B&H and im in Australia, how does the warranty work?
Rudi
Joined Mar 2002
May 21, 2008 09:48 |  #5
Aszental wrote in post #5242108 (external link)
Ring B&H, they'll sort you out. :)
• Wedding Photographer - Sydney and Wollongong (external link)
• Borrowed Moment (blog) (external link)
Life is uncertain. Eat dessert first.
tenoverthenose
May 21, 2008 12:29 as a reply to  @ Rudi's post |  #6
This just happened with one of my transmitters and was easily fixable in about 30 seconds with a paper clip. The slide pin was bent in on mine.
1. Use a paper clip to "short" the connection between the side pin and the bottom pin of the transmitter. If it fires your flash, continue on - if not, send it in to be repaired.
2. Use the paper clip to gently (I am not responsible if you break it) pry the side pin out so that it makes better contact with the hotshoe.
3. Test it in the hotshoe and everything should work.
www.patrickpike.com (external link) | twitter (external link) | facebook (external link)
1,382 views & 0 likes for this thread, 5 members have posted to it.
2771 guests, 173 members online
