With regard to IR work - Does anyone know of a filter that will block all normal light, just leaving the IR range of light frequencies??
Vulcan58 Goldmember 1,790 posts Likes: 1 Joined Jun 2007 Location: Hampshire, UK More info | Apr 03, 2008 04:54 | #1 With regard to IR work - Does anyone know of a filter that will block all normal light, just leaving the IR range of light frequencies??
wnelson Member 99 posts Joined Jan 2008 Location: Wirral, UK More info | Apr 03, 2008 06:32 | #2 Vulcan58 wrote in post #5250693 With regard to IR work - Does anyone know of a filter that will block all normal light, just leaving the IR range of light frequencies?? A (very) incomplete list follows. You will find dozens of posts here which can help you. You'll probably getter a better answer if you advise which camera you are intending to use and also the 'type' of infrared image you are trying to achieve (false colour, B&W etc)
Apr 03, 2008 07:33 | #3 Thanks Mods for moving this to the correct forum.
wnelson Member 99 posts Joined Jan 2008 Location: Wirral, UK More info | Apr 03, 2008 08:47 | #4 Vulcan58 wrote in post #5251107 Thanks Mods for moving this to the correct forum. Thankyou for the reply /advice wnelson - this wasn't actually for me, but for a colleague of mine who was making general enquiries about IR, and I just mentioned that if I could find an answer it would be on here - ever helpful forum. Cheers V58 No problem - just warn him that if he uses an external filter on the camera, his exposures are going to be *very* long, he won't be able to see much (if anything) through the viewfinder and will have to make manual focus adjustments.
rang Goldmember 1,644 posts Likes: 6 Joined Jan 2007 More info | Apr 03, 2008 10:51 | #6 Vulcan58 wrote in post #5250693 With regard to IR work - Does anyone know of a filter that will block all normal light, just leaving the IR range of light frequencies?? Good answers above... Lotsa stuff, running outta room and a wife...I keep looking at her and wondering???
| Latest registered member is semonsters 916 guests, 109 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
