Thread started 15 Nov 2004 (Monday) 04:16
Very Silly question , but cant find in manual
dpp
Joined Oct 2004
Nov 15, 2004 04:16 |  #1
Hi
When I turn on the EOS 10D I get "PA-A".
Any ideas what it means
Sorry stupid question
Cadwell
Joined Jan 2004
Nov 15, 2004 04:20 |  #2
From memory I believe it means you're running a non-standard set of image parameters... Sharpness, Contrast, Saturation etc...
Glenn
My Pictures: Motorsport (external link)/Canoe Polo (external link)/Other Stuff (external link)
Morden
Joined Oct 2002
Nov 15, 2004 05:12 |  #3
You have selected Adobe RGB as the colour space for your captured images.
defordphoto
MKIII Aficionado
Joined Oct 2002
Nov 15, 2004 05:16 |  #4
That is correct.
defordphoto | Celebrating the art of photography®
SD500, 10D, 20D, 30D, 5D, 1DMKII, 1DMKIII
www.ussbaracing.com (external link) | www.rfmsports.com (external link) | www.nwfjcc.com (external link)
An austere and pleasant poetry of the real. Ansel Adams
lensmen
Joined Oct 2004
Nov 15, 2004 05:32 |  #5
Sorry to hijack this thead but what exactly is the Adobe RGB setting on my 300D.... I dun quiet get the manuals' explaination
Jimmy
Just my 2 frame's worth :D:D:D
My Gear List
500px album (external link)
dhbailey
Joined Oct 2004
Nov 15, 2004 05:39 |  #6
There are several (many?) different ways of interpreting RGB (red, green, blue) color data, which can result in the same picture looking slightly different depending on the interpretation.
sRGB is, if I recall correctly, the standard interpretation that many applications use, and thus is the most versatile for using between different applications.
AdobeRGB is a proprietary interpretation which has more varying shades of color and thus can give a better interpretation of the picture's colors but it only works with programs which have been designed to handle it, and that most likely involves purchasing an expensive SDK from Adobe.
So only take pictures with the camera set to AdobeRGB if you know you have an application that can handle it.
Otherwise leave it set to sRGB.
If I have misunderstood this matter, then I am sure lots of ridicule will be heaped on my poor head but I will learn. :D
David
Cameras: S3is and 20D
Canon 18-55 kit lens, 50mm 1.8, 75-300 USM IS
Tamron 28-75 F2.8, 420EX flash
Jesper
Joined Oct 2003
Nov 15, 2004 06:45 |  #7
Your first line is correct. The RGB values in an image don't mean anything by themselves. For example, what shade of green is (0, 255, 0)? Is it grass green, or more yellow green, or ...? To be able to tell exactly what colour it is, you have to specify the colour space in which the numbers are measured. Just like you measure distances in miles or kilometers - the number without the unit doesn't mean much.
Your last line is incorrect. Colour spaces are specified using ICC (International Colour Consortium) profiles. On your computer, an ICC profile is stored in a small file with the extension *.icc or *.icm. There are lots of different standard colour spaces, and sRGB and Adobe RGB are the two which are used most. For an application to support Adobe RGB the software developers do not need any special SDK from Adobe. They just need to make their application colour management aware.
That's good advice. If you want to learn more, you'll have to find more information about colour management, which is a complicated subject for many people. If you don't want to be bothered with all the technical details, leave the camera on sRGB, which will give you good results without having to know how all the details work.
Canon EOS 5D Mark III
1,712 views & 0 likes for this thread, 7 members have posted to it.
1938 guests, 100 members online
