Thread started 04 Apr 2008 (Friday) 04:12
inexpensive slide/negative scanner
2005GLI
Apr 04, 2008 04:12 |  #1
I have come up empty trying to find the slide/negative trays for my epson 3200 scanner. I was hoping they were in the box but they are not. I dont want to send the hundreds if not thousands of my late fathers slides out to be scanned, $$$$$$$. So I was searching ebay and found a few inexpensive scanners but not sure if i'de buy them. I did a google on one of them and it is beeing sold on national geographic's site.
NG.com slide/negative scanner (external link)
Should I bite the bullet and just get it on ebay since its a little cheaper or look elsewhere?
|Canon 80D|40D backup|24-105 F4/L|Sigma 70-200 F/2.8|Sigma 150-500 C|
|Tokina 12-24|Sigma 8mm Fisheye|
GyRob
Apr 04, 2008 07:04 |  #2
ah iv just read up on this as i was going to get one and a few say it has poor IQ and has auto corection that often is way off so i would look into it more before buying one.
Rob.
"The LensMaster Gimbal"
GyRob
Apr 04, 2008 07:21 |  #3
i think something like this may be the best bet as long as you can get the full slide in .
http://www.kauserinter​national.com …/Ohnar%20Digita​l_Zoom.htm (external link)
2005GLI
Apr 05, 2008 05:10 |  #4
how does that work? you need to attach to your own lens or does that go straight onto the camera?
i saw an HP slide/film scanner on ebay, i googled that and new it was like $130. Would it be more worth while looking at that?
HankScorpio
Apr 05, 2008 05:48 as a reply to  @ 2005GLI's post |  #5
I bought a Plustek Optifilm 7200 scanner and have found it excellent.
http://www.plustek.com​/product/7200.asp (external link)
They aren't dirt cheap but if you have lots of 35mm negs or slides or are still shooting 35mm like me then it is well worth the price.
It's no good for medium format though, just does 35mm negs up to 6 frames long and mounted or loose slides.
My collection of boxes with holes (external link)
EXIF semper intacta.
Gort! Klaatu barada nikto.
GyRob
Apr 05, 2008 07:29 |  #6
2005GLI wrote in post #5264230 (external link)
Bottom of the page you buy a t2 adapter for your camera -you dont use a lens with it .
Rob.
RandyMN
Apr 05, 2008 07:40 |  #7
I'm not sure what inexpensive is defined as because I paid 219.00 for an epson off Amazon and that seemed cheap to me.
My old scanner is a HP Photosmart S520 and it is no longer supported under Windows Vista, so I'd give away that one if one if I knew someone locally who could use it. Now there is a cheap scanner!
GyRob
Apr 05, 2008 07:46 |  #8
the problem with the one you saw on eby is the time it take's to do a full hi IQ scan copied from there site (Interface: USB 2.0
Technology: Colour CCD image sensor
Hardware Resolution: 7200 x 7200 dpi
Dmax: 3.5
Max. scanning area: 36.8 x 25.4 mm (1.45 "x 1") *
Preview Speed: 6.25 sec (positive film), 8.72 sec (negative film) without calibration
Scan Speed: Approx. 87 sec (3600 dpi), 226 sec (7200 dpi) for colour slide
Hardware Multi-Exposure on negative film: Yes )
THE ONE i showed you once set up you just take a pic with your camera so its far quicker .
Rob.
Jon
Joined Jun 2004
Apr 05, 2008 08:01 |  #9
GyRob wrote in post #5257771 (external link)
I don't think, from the specs, that the T-mount adapter will let you get more than 40% of your 35 mm slide or neg. on a crop DSLR; you'd need a 5D or 1Ds to get a full slide in (it captures at 1:1 to 2:1).
If a film scanner of adequate (1200 dpi native is a minimum) resolution isn't available, go for a dual-purpose scanner unless you're willing to pay $500 or more.
Jon
Cocker Spaniels
GyRob
Apr 05, 2008 08:16 |  #10
thanks for clearing that Jon i was not sure if the OP could get the full slide in or not on the 40d.
Rob.
2,146 views & 0 likes for this thread, 5 members have posted to it.
1074 guests, 114 members online
