Thread started 04 Apr 2008 (Friday) 11:11
Prime Lens ? How many of you have them?
Cody21
Apr 04, 2008 11:11 |  #1
OK, I keep reading about the PRIME lenses and feel like I'm missing out on something important. These appear to be "better" than Zoom lenses, WHY?
So do you have a PRIME Lens? if you only had 1 ($$), what would it be and WHY?
Both of my lenses are Zoom lenses.
5DM3 | 16-35mm f/2.8L II USM | 70-200mm IS f/4L | 24-105 f/4L | Sigma 18-50mm f2.8 | Speedlite 430EX
eddarr
There's Moderators under there....
Apr 04, 2008 12:17 |  #2
By default prime lenses will generally have better image quality then zoom lenses. Typically there are fewer elements and fewer groups. Less glass that can cause distortion between the subject and the sensor usually will give a sharper image.
Some will argue though that todays zooms are catching up in terms of image quality. This may be true and it may not, it will depend on who you ask and your own experience.
The biggest advantage to primes is they are usually faster i.e. 50 f1.2. The biggest disadvantage is of course the lack of zoom. I have a really hard time not reaching for the length ring when using a prime.
I would suggest trying the 85 f1.8 if you want to try primes. It's next on my list and seems to be the best bang for your buck.
Eric
René ­ Damkot
Apr 04, 2008 12:21 |  #3
I have a 20/1.8, 28/1.8, 35/2.0, 50/1.4 and 100/2.0.
They are better and faster then my 20-35L and 28-105 respectively.
The 100 is about equal to the 80-200L (but AF on the L is way more accurate in AiServo)
Speed is more important then the difference in IQ IMO.
Then again, a cheap zoom will be less on both points.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Cody21
Apr 04, 2008 12:22 |  #4
Thanks ... so if I'm seeing this 'lack of zoom' correctly, you have to move closer/further from the subject to get the correct frame you're wanting. So a Prime is a better over-all "walk around" lens - say for events, parties, weddings, etc.
beezwax
Apr 04, 2008 12:23 as a reply to  @ René Damkot's post |  #5
I only have the Nifty Fifty 1.8 50mm
why?
it's cheap and it does the trick.. I haven't really used it much...
MYGEAR
GULFCOASTTUNDRAS.com (external link)
eddarr
Apr 04, 2008 12:25 |  #6
It's just a different kind of zoom. It's called foot zoom. Personally, I like primes when I can control the distance. For something like a party or wedding I would prefer a zoom rather than pushing people around.
Eric
oaktree
Apr 04, 2008 12:34 |  #7
I have 6 primes and use them when I need a fast lens (f/2.8 or wider) for low light situation like indoor sports and indoor/night concerts. Singly, primes are generally shaper, lighter, and cheaper than similar focal length zooms. But you'll need more than one to cover any zoom's range so the weight and price advantage of a single prime could disappear if you buy more than one.
When I travel, I take my 17-55/2.8 and 70-300/DO zooms (along with a 100/2.0 prime). I'm not traveling with 6 primes!
Too much stuff, not enough shooting time.
Canon T4i (2 lenses), Fuji X100s, Olympus OM-D EM-1 (3 lenses)
René ­ Damkot
Apr 04, 2008 12:44 |  #8
Cody21 wrote in post #5259451 (external link)
No. you have to crop.
If you move, you'll change perspective...
(might write a sticky about this as well :p)
Bill ­ Roberts
revolting peasant
Apr 04, 2008 12:46 |  #9
Primes are typically lighter, sharper, faster and cheaper than zooms. But oaktree (above) is right, sometimes you just don't want to carry a whole load of lenses around with you, and the advantages disappear. In that case you're better off with a zoom.
But... if you do know what you're going to be shooting, and the FL needed for the job, then the prime wins big time. I'm afraid everything in life tends to be a compromise and lenses are no exception!
cheers
BiLL
oaktree
Apr 04, 2008 13:01 |  #10
Bill Roberts wrote in post #5259587 (external link)
Well said!
timnosenzo
Apr 04, 2008 13:01 |  #11
Here's my story... I started off as a zoom only kind of guy, really not seeing much value in prime lenses. Last year I began to feel like maybe "less is more" under certain circumstances. I hated always being the guy with a HUGE camera and HUGE lenses. At the time I had a 24-70 L that I loved dearly, my 70-200 f/2.8 L, and my 17-40 L. I decided that for a walk around lens, my 24-70 wasn't ideal and I wanted to try out a 24-105... turns out I really LOVED the 24-105. Awesome all around lens.
So I decided I would sell my 24-70 and try out primes for low light stuff. I bought my 28 f/1.8, 50 f/1.4 & 85 f/1.8. I LOVE using them at parties & bars, out with friends, leaving the flash at home, etc. 85 is an awesome portrait lens, or for anything where you want to isolate your subject. So low light, they're great, size wise, they're great--small & lightweight... I'm now trying to get myself using them more under normal conditions where light isn't so much the problem. So far I'm having fun with it. I don't think I'll ever give up my zoom lenses, but having one or two prime lenses can really open the door up to some new possibilities.
Sorry for the long post, hope it helps.
Tim
Mcary
Apr 04, 2008 13:07 |  #12
Cody21 wrote in post #5259023 (external link)
If I only had one prime it would probable be the 85 1.2 or 85 1.8
Currently use the 35 2.0, 50 1.4, 85 1.8 and just bought the 135 2.8SF, just got it and have only used it for one shoot but very pleased so far.
Mike
OMG I saw a nipple, my eye's are bleeding!
Visit http://www.mcaryphoto.​net (external link) (Nudity) warning most images found on this website were shot with cheap plastic lens (50mm 1.4 85 1.8 and 35 2.0)
bacchanal
Apr 04, 2008 13:26 as a reply to  @ oaktree's post |  #13
I have 3 primes and 1 zoom. I don't know if I could pick just one, I love them all so much! :D:rolleyes:
Anyway, my reason for owning primes is for low light. My one zoom, the 17-55, has pretty darn good IQ...it certainly holds it's own w/ the primes anyway.
narlus
Apr 04, 2008 14:18 |  #14
i have 4 primes.
15 sigma f/2.8 fisheye
canon 50 f/1.4
canon 85 f/1.6
canon 135L f/2
i love them all, and use them quite a bit.
but if i am looking to travel kinda light, and there's plenty of available light, the L zooms get more play.
www.tinnitus-photography.com (external link)
Facebook link (external link)
gear list
Cody21
Apr 04, 2008 14:33 |  #15
Thanks everyone for the great info !!
5,174 views & 0 likes for this thread, 35 members have posted to it.
2767 guests, 177 members online
