Thread started 04 Apr 2008 (Friday) 15:19
aperture/iso setting on flash when using it off-camera
Stephan.
Apr 04, 2008 15:19 |  #1
When using a speedlite off-camera, do manual aperture and iso settings on the flash have any meaning at all?
Curtis ­ N
Master Flasher
Apr 04, 2008 17:59 |  #2
Sure they do.
If the Speedlite is in manual mode, aperture and ISO will affect exposure (along with flash power setting, distance, modifiers and a few other things).
If the Speedlite is in E-TTL mode, the E-TTL system will attempt to account for the aperture and ISO settings as much as its power allows. Opening the aperture or raising the ISO will allow shooting at a greater distance from flash to subject. At a given distance, it will reduce the amount of power required, improve recycle time and increase battery life.
Stephan.
Apr 05, 2008 05:48 |  #3
Thanks Curtis! I used to only use the power setting (being the most obvious) and the distance setting on my off-camera flash in manual.
So if I set the flash to ISO 100 and 1/4 power it will give more output than if I'd set it to ISO 1000 and 1/4 power, right?
Curtis ­ N
Master Flasher
Apr 05, 2008 07:59 |  #4
Ok, back up a minute.
I think I misunderstood your question.
What flash unit are you using?
Stephan.
Apr 05, 2008 09:51 |  #5
This question refers to a Nikon SB-28 DX.
PacAce
Joined Feb 2003
Apr 05, 2008 10:07 |  #6
And what mode are you using the flash in? If in manual mode, none of the settings other than the power level is meaningful. If in auto mode, then the ISO and aperture set on the flash will make a difference in the exposure.
...Leo
Stephan.
Apr 05, 2008 11:46 |  #7
I'm using it in the manual (M) mode.
Isn't the zoom setting of any relevance?
René ­ Damkot
Apr 05, 2008 13:48 |  #8
zoom setting is, because more light goes to the subject, less to the surrounding erea;)
Flash puts out the same amount of light, but it's "concentrated more" so to speak.
ISO only alters the "distance scale" on the back of the flash.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
Stephan.
Apr 06, 2008 12:24 |  #9
Thanks René for the clarification.
1,829 views & 0 likes for this thread
Latest registered member is Carlasandovalo
692 guests, 192 members online
