Thread started 15 Nov 2004 (Monday) 20:53
EL-Cheapo Macro
Headcase650
Joined Jun 2004
Nov 15, 2004 20:53 |  #1
With all this Macro talk I thought Id show you all what I found today. My girlfriends granfather died a few years ago and left her all his old manual Minolta equipment, body, 50mm 1.7, 90-230 4.5, macro bellows, a flash and a box full of junk. Well going through the box today I found a set of Camron 52mm close up filters. A +1, +2 and a +3. I thought hey they will fit my 50 1.8 so I did some playing around. This is just a quick test at ISO 200 color is off but I havent touched the files except to resize them. I shot from a downward angle on a trypod so the depth of field is paper thin. Adding each new filter and scooting the camera up until it wouldnt auto focus then pulling it back just slightly.
I uploaded the pics to another message board, hears the link
http://groups.msn.com …e&mview=0&ID_Me​ssage=6354 (external link)
60D, Canon 18-135 IS, Sigma 10-20 hsm, 24-70 2.8 hsm, 70-200 2.8 hsm, 430EX II, and all the other stuff that goes along with it.
FlyingPete
I am immune
Joined Oct 2003
Nov 15, 2004 21:24 |  #2
Got a set of these I have had for a number of years, they seem to do the trick.
As I have never used a real macro lens, what are the advantages over a good lens with the close up 'filters'? (I'm guessing clarity for starters)
Reverse mounting a lens is another goodie at a cheap solution, if you can find a way of mounting it, had my 28-105 reverse mounted on my G3 until I discovered the secret of super macro :wink:
Peter Lowden.
EOS R6 and assorted glass
FlyingPete
I am immune
Joined Oct 2003
Nov 15, 2004 21:28 |  #3
There are also those Macro extension rings as well, I believe the issue there is you lose so many stops per extension length. Had a bellows on my OM1, so close it was almost unusable!
Peter Lowden.
DocFrankenstein
Joined Apr 2004
Nov 15, 2004 21:28 |  #4
Yeah... those are fun to play with.
I've got some set of dusty close up filters with my 50mm prime also. Today I got an extension cable for the flash, do I'll soon be able to get a bug and blast it with my vivitar close up at F/22
I expect the bug to last 2-3 flashes till it goes crusty :lol: :lol:
National Sarcasm Society. Like we need your support.
wolf
Joined Sep 2004
Nov 15, 2004 23:06 |  #5
Yes, extension tubes are fun. Put them on a long zoom and you can really have fun.
<> My Gear <>
rkoshy
Joined May 2004
Nov 15, 2004 23:23 |  #6
Ok... just ordered the 25mm extension tube... What can it really do with a 70-200 zoom?
1. Is there some way to calculate my minimum distance for the focus to work?
2. I read another thread that leads me to believe it will magnify the image about 27% or so... is that true?
DRebel | Sigma 70-200 f/2.8 EX APO | Sigma 24-60 f/2.8 EX DG | Canon 50 f/1.8 II | Canon EF-S 18-55 (Kit) | Sigma TC x1.4 | Canon Tube 25mm | Canon 550EX | Assorted Filters
wolf
Joined Sep 2004
Nov 16, 2004 00:25 |  #7
[QUOTE]
rkoshy wrote:
="rkoshy"]
The rough calculation for percentage of magnification is: Divide the focal length (mm) of the lens by the length of the extention tube (mm) for an approximate percentage.
There is a formula for an exact % which is not much different in percentage than the rough % calculation.
I have not found a chart or calculation for minimum focus distances for a lens longer than 50mm yet. If someone knows of one on the net I would be glad to get the link.
I just shot this tonight as an example of distance in another forum.
Shot at 3 feet from subject with 68mm of extension at a focal length of 200mm.
Full frame -resized
100% crop of the above
<> My Gear <>
Jesper
Joined Oct 2003
Nov 16, 2004 01:22 |  #8
Here is a good macro tutorial (external link), which explains the different options you have when you want to do macro photography - macro lenses, extension tubes, close-up lenses etc.
Canon EOS 5D Mark III
Scottes
Trigger Man - POTN Retired
Joined Nov 2003
Nov 16, 2004 07:41 |  #9
This *completely* depends on the extension tube length as compared to the lens length. Putting a 25mm tube on a 50mm lens will result in a huge difference. Put that same tube on a 500mm lens and it will make a slight difference.
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info (external link)
Follower of Fidget - Joined the cult of HAMSTTR©
1,624 views & 0 likes for this thread, 7 members have posted to it.
EL-Cheapo Macro
1606 guests, 123 members online
