Anyone using one of these?
http://cgi.ebay.com …048&rd=1#ebayphotohosting![]()
Can I trust it? Is it better to get the Canon branded ones?
thanks.
booggerg Senior Member 460 posts Joined Aug 2004 Location: Chicago More info | Nov 16, 2004 21:54 | #1 Permanent banAnyone using one of these? 20D || EOS650 || 50 f/1.8 MKI || 17-40 f/4L || 70-200 f/4L || Sigma 35-135 f/3.5 || Yashica Electro 35 || Yashica Minister || Yashica Mat 124G || Hoga 120CFN || 420EX || Sekonic 306 || Panasonic DVX100 || Canon GL2
jwhee0615 Member 54 posts Joined Jul 2004 Location: Plano, TX. More info | Nov 16, 2004 22:23 | #2 I just received mine. works fine. pretty quick shipping from china too. EOS 20D
CyberDyneSystems Admin (type T-2000) More info | Nov 16, 2004 22:41 | #3 Cool! It;s about time someone did this.. us 10D owners used to have to shell out $40.00 for a plastic switch! GEAR LIST
RDKirk Adorama says I'm "packed." More info | Nov 19, 2004 09:29 | #4 booggerg wrote: Anyone using one of these? http://cgi.ebay.com …048&rd=1#ebayphotohosting Can I trust it? Is it better to get the Canon branded ones? thanks. I got one. Works fine. At first it didn't, but I plugged and unplugged it a few times, then it was okay. Some coating to be worn off, I suppose. TANSTAAFL--The Only Unbreakable Rule in Photography
Toogy "I like pictures of myself!" 6,248 posts Likes: 3 Joined Nov 2003 Location: Ontario, Canada More info | Nov 19, 2004 09:48 | #5 I got one and it works fine.
Whaler Senior Member 445 posts Joined Mar 2003 Location: S.F. Bay Area Kalifornia More info | Nov 19, 2004 10:19 | #6 Bought generics for both my D300 and 20D, both work fine. I'm a Proud Supporter of P.E.T.A.
aznkid.com Member 134 posts Joined Feb 2004 Location: Toronto, Canada More info | Nov 19, 2004 10:59 | #7 i ordered the exact same one..
chuckindetroit Member 33 posts Joined Jan 2002 More info | Nov 19, 2004 13:06 | #8 I just received one from a different seller that was located in the US. It didn't work in the first position, autofocus, bud would take a picture when pressed all the way. I emailed the seller and he had a replacement in the mail the next day. The problem was a poor crimp job on an internal connector pin in the switch housing. I soldered it and life is good. The cord is about three feet long which is not quite usefull enough. What I plan to do is cut the cord in half and crimp modular phone plugs on each end and creat an extension cable to go in between. Should cost all of a dollar three two ninety eight!! The useful part of these cheap remotes is the plug. You could hook it up to all manner of home made wireless remote, relay outputs, etc.
| Latest registered member was a spammer, and banned as such! 1937 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
