Thread started 09 Apr 2008 (Wednesday) 01:21
Cakes and Table Settings
adamfromperth
Apr 09, 2008 01:21 |  #1
Hi guys,
Just wodnering how everyone shot their cakes/table settings what camera settings...
mlbbunny
Apr 09, 2008 15:46 |  #2
depends on how much ambient light is available, if I'm using flashes, if I'm using a tripod, what lens I'm using, and what effect I want. There is no set camera setting for this because the situtations can be so different. It's best to learn your manual camera settings and play with it until your happy. Sorry I wish I could give you a formula but it isn't quite that easy.
samnz
Joined Feb 2006
Apr 09, 2008 16:26 |  #3
...depends too if it's single layered, multi-tiered, ornamented or naked, iced or creamed, fruit or chocolate, white or dark ...... CRAP: HUNGRY NOW!!! :(
SAM
Gear
mlbbunny
Apr 09, 2008 18:44 |  #4
yummm wedding cake your making me hungry for it too! lol
kevin_c
Apr 11, 2008 12:54 |  #5
Back to the original question... ;)
One of the main things to consider is the correct exposure. Most cakes are decorated with white icing and they tend to be placed on a white table cloth - so if you meter off this ensure you set about +1 stop(ish) exposure compensation or adjust manually to achieve this. You will usually have the chance to 'chimp' this so just check the histogram and ensure you don't clip the highlights (The RH side of the histogram)
You will be able to lighten slightly in post-processing to bring the white back if needs be, but you can't recover burnt-out whites so whatever you do don't over expose.
Also try to do something a bit different to the usual 'cake on a table' shot :rolleyes: - By all means get this as a 'record' shot but try to be creative using shallow depth-of-field and/or unusual angles etc.
-- K e v i n --
Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4
Canon EOS 3, 24-105L, 135L
713 views & 0 likes for this thread, 4 members have posted to it.
2818 guests, 173 members online
