looking to find out what all i need to mount my 420 on a bracket when i shoot formals and so forth.
i know i need the off shoe cord
a bracket....
what else.. any other help would be great. thanks
arul
jaisai01 Senior Member 277 posts Joined Oct 2004 More info | Nov 17, 2004 23:27 | #1 looking to find out what all i need to mount my 420 on a bracket when i shoot formals and so forth. Canon 5D/ BG-E4 Grip /Canon 20d / BG-E2 Grip / 18-55mm kit / 28-135mm IS / 50mm f1.8 / 70-200f4L / 24-105f4L IS/ 550ex Flash / 420ex Flash (on umbrella) / all packed in a Pelican 1510 w/ Dividers & Photographic Organizer
redbutt Senior Member 619 posts Joined Aug 2001 Location: Carlsbad, CA More info | Nov 17, 2004 23:30 | #2 You could get the Canon flash controller thingy and do it all without cables...and give yourself the flexibility to put the flash just about anyhere...on or off the camera.
Nov 17, 2004 23:37 | #3 since im only using the 420 i dont think the throw is enough. but what kind of bracket should i get. is more of the ? Canon 5D/ BG-E4 Grip /Canon 20d / BG-E2 Grip / 18-55mm kit / 28-135mm IS / 50mm f1.8 / 70-200f4L / 24-105f4L IS/ 550ex Flash / 420ex Flash (on umbrella) / all packed in a Pelican 1510 w/ Dividers & Photographic Organizer
vfilby Senior Member 728 posts Joined May 2004 Location: Guelph, ON More info | Nov 18, 2004 01:57 | #4 jaisai01 wrote: since im only using the 420 i dont think the throw is enough. but what kind of bracket should i get. is more of the ? What do you mean "the throw is [not] enough"? As in you need more light? A flash bracket won't add light it will just position the flash higher for more natural looking shadows (from above like the sun), less chance of red eye, and usually a less flattened picture (typical of shoots where the flash is really close to the lens). Glass and plastic
scottbergerphoto Cream of the Crop 5,429 posts Likes: 1 Joined Jun 2003 Location: Brooklyn, NY, USA More info | Nov 18, 2004 06:03 | #5 There are many brackets available from Stroboframe, Bogen-Manfrotto, Really Right Stuff, Kirk, Custom, Lindahl, Newton, etc. They can get very expensive. Your best bet is to start off with something from Stroboframe or this one from Bogen http://www.bhphotovideo.com …ails&Q=&sku=278249&is=REG One World, One Voice Against Terror,
rickyd Member 79 posts Joined Jan 2003 More info | Nov 18, 2004 07:34 | #6 Be sure to buy a genuine Canon cable to connect your camera to the flash on your new bracket. I used an after market cord and found at the worst possible time (a wedding) that my 1Dmk2 wouldnt talk properly with my 550ex flash.!
Nov 18, 2004 08:33 | #7 the bogen bracket you have shown me, will that work with my grip on . and also when the camera is vertical will it position it self for vertical shots. thanks Canon 5D/ BG-E4 Grip /Canon 20d / BG-E2 Grip / 18-55mm kit / 28-135mm IS / 50mm f1.8 / 70-200f4L / 24-105f4L IS/ 550ex Flash / 420ex Flash (on umbrella) / all packed in a Pelican 1510 w/ Dividers & Photographic Organizer
scottbergerphoto Cream of the Crop 5,429 posts Likes: 1 Joined Jun 2003 Location: Brooklyn, NY, USA More info | Nov 18, 2004 09:01 | #8 jaisai01 wrote: the bogen bracket you have shown me, will that work with my grip on . and also when the camera is vertical will it position it self for vertical shots. thanks arul The Bogen bracket will work with a grip. It is not as easy to switch to portrait from landscape as the others, so if you plan on changing orientation alot pick one of the others. Some flip the flash, others rotate the camera. One World, One Voice Against Terror,
Nov 18, 2004 09:05 | #9 basically i want to mount the camera to a tripod and then have the bracket also.. which i hope will work. im jsut going to be taking pictures in a vertical mode. will this work. no changing will be needed.. Canon 5D/ BG-E4 Grip /Canon 20d / BG-E2 Grip / 18-55mm kit / 28-135mm IS / 50mm f1.8 / 70-200f4L / 24-105f4L IS/ 550ex Flash / 420ex Flash (on umbrella) / all packed in a Pelican 1510 w/ Dividers & Photographic Organizer
scottbergerphoto Cream of the Crop 5,429 posts Likes: 1 Joined Jun 2003 Location: Brooklyn, NY, USA More info | Nov 18, 2004 09:27 | #10 jaisai01 wrote: basically i want to mount the camera to a tripod and then have the bracket also.. which i hope will work. im jsut going to be taking pictures in a vertical mode. will this work. no changing will be needed.. thanks arul If you want a bracket that will let you mount your camera to a tripod in the vertical position you either need to buy an L bracket or a flash bracket that rotates the camera like the Stroboframe Pro RL. One World, One Voice Against Terror,
Nov 18, 2004 16:21 | #11 scott, Canon 5D/ BG-E4 Grip /Canon 20d / BG-E2 Grip / 18-55mm kit / 28-135mm IS / 50mm f1.8 / 70-200f4L / 24-105f4L IS/ 550ex Flash / 420ex Flash (on umbrella) / all packed in a Pelican 1510 w/ Dividers & Photographic Organizer
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | Nov 18, 2004 16:31 | #12 scottbergerphoto wrote: If you want a bracket that will let you mount your camera to a tripod in the vertical position you either need to buy an L bracket or a flash bracket that rotates the camera like the Stroboframe Pro RL. Scott Scott, my tripod has a normal pan-tilt head with quick release, and the head will "flop" to one side as necessary.
johneo Goldmember 1,428 posts Likes: 1 Joined Aug 2003 Location: North Kingstown, RI More info | Nov 18, 2004 17:08 | #13 You may also want to get a bouncer or softbox ... I have the Lumiquest Pocket Bouncer, works great, but there may be others that you should look at. 2 - 5DMKII's, Powershot SX 150 IS
scottbergerphoto Cream of the Crop 5,429 posts Likes: 1 Joined Jun 2003 Location: Brooklyn, NY, USA More info | Nov 18, 2004 21:19 | #14 robertwgross wrote: scottbergerphoto wrote: If you want a bracket that will let you mount your camera to a tripod in the vertical position you either need to buy an L bracket or a flash bracket that rotates the camera like the Stroboframe Pro RL. Scott Scott, my tripod has a normal pan-tilt head with quick release, and the head will "flop" to one side as necessary. What happens to your flash when you flop the camera on its side Bob? One World, One Voice Against Terror,
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | Nov 18, 2004 21:44 | #15 scottbergerphoto wrote: What happens to your flash when you flop the camera on its side Bob? In addition, I dont like the awkwardness of the camera with the tripod head turned on its side. The camera likes to try to droop down. Kirk and RRS (Really Right Stuff) make very nice L brackets. If you buy a camera rotator type flash bracket, you don't need an L bracket. You mount the bracket to the tripod head. Well, my flash is on the bracket, and it is a flip-type bracket, so if I flip the camera over to vertical (to the right), I flip the flash to vertical (to up).
| Latest registered member was a spammer, and banned as such! 1945 guests, 122 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
