Rayz wrote:
Interesting! I usually raise ISO a notch when I want a faster shutter speed. But that's probably because I shoot aperture priority most of the time. However, in situations where the ISO setting is likely to cause unacceptable noise (800 on my D60 and perhaps 1600 & 3200 on the 20D), I'll sacrifice DoF and reduce the F stop #.
I normally shoot aperture priorty myself--wide open--as it will give me the highest possible shutter speed. If I weren't such an old fogey, I might shift ISO a bit more readily--high ISOs are certainly more usable in digital than in film (I have to chuckle at people who are aghast at ISO 3200 20D noise--they must never have tried to boil fujichrome to 3200)
Rayz wrote:
However, I agree that in all cases it's necessary to use an adequate shutter speed to get a sharp hand-held shot. Balancing the trade-offs between lens performance at a particular aperture, camera shake at a particular shutter speed and noise at a particular ISO setting, can be tricky. For example, if the Tamron 17-35 is noticeably sharper at f5.6 than at f2.8 (which I think it probably is), having selected an appropriate shutter speed to ensure maximum sharpness (say, double the 1/focal length rule), one might then be faced with a choice of f2.8 with ISO 100 or F5.6 with ISO 400.
TANSTAAFL is the only unbreakable rule in photography. But the Tamron's quality barely changes as you stop down. It's pretty much at maximum sharpness at maximum aperture. And DoF is pretty good at all focal lengths, too.
Rayz wrote:
Supposing DoF is not an issue, ie. the pros and cons are about the same, esthetically. Would you not choose F5.6 for a sharper result?
As above, it's not significantly sharper with the Tamron--I have zero fear of working at maximum aperture with it.
