Thread started 18 Nov 2004 (Thursday) 21:26
manual vs auto focus
transcend
Joined Oct 2004
Nov 18, 2004 21:26 |  #1
I have a 17-40L on my 10d, recently i have been noticing images seem sort of soft. I ran a few quick very unscientific tests, and it seems that the AF almost 100% of the time, focuses a bit more softly then by hand.
If i manually focus i can get it razor sharp, otherwise i cannot.
This was on a tripod, 180/sec, iso 200, flash on and flash off. No chance of hand shake (which i normally attribute to this, but which doesnt appear to be the case as it happens at all shutter speeds.
Is this normal and am i just paranoid? Or should i look into having it calibrated?
http://www.fraserbritt​on.com (external link)
FlipsidE
Joined Oct 2004
Nov 18, 2004 21:50 |  #2
The camera and/or lens could be front focusing or back focusing. Unfortunately, I don't have the links to point you toward the tests, but there are front focus and back focus test available.
FlipsidE
FlipsidE
robertwgross
Joined Nov 2002
Nov 18, 2004 21:54 |  #3
My camera and long lens were having a "softness" problem starting just a few days ago. Finally, I looked at it and the viewfinder eyepiece diopter setting had gotten tweaked. As soon as I re-tweaked it, the problem went away.
---Bob Gross---
EXA1a
Joined Oct 2003
Nov 19, 2004 03:04 |  #4
Please don't mix up the terms "soft" and "out of focus". You are talking about a potential misfocussing problem, right?
transcend
Joined Oct 2004
Nov 19, 2004 06:34 |  #5
Possibly a misfocus problem, possibly just the lens being soft and completely normal. This is an L lens however, i expected much better performance then I am getting, especially when at middle apertures. Wide open i expected it to be a bit soft.
I have front abd back focus tests now, so i will give it a shot this afternoon
EXA1a
Joined Oct 2003
Nov 19, 2004 07:13 |  #6
In your original post you found differences between MF and AF shots, and that's misfocusing for sure.
jalafer
Joined Dec 2003
Nov 19, 2004 07:49 |  #7
FlipsidE
A very simple focusing test.
Put your camera on a solid tripod in front of a wall.
Put a printed sheet on the wall (a wall with painted paper would be Ok).
Make one picture in AF, then turn the camera on MF, focus manually and make the second picture.
Check the results in your computer screen, if MF is better than AF, then your camera is frontfocussing. Take into account that you can have this probelm with one lens and not have ot with another.
Scottes
Trigger Man - POTN Retired
Joined Nov 2003
Nov 19, 2004 08:20 |  #8
But if AF is better this test means nothing, because the diopter could be off.
You can take my 100-400 L away when you pry it from my cold, dead fingers.
Scottes' Rum Pages - Rum Reviews And Info (external link)
Follower of Fidget - Joined the cult of HAMSTTR©
PacAce
Joined Feb 2003
Nov 19, 2004 08:54 |  #9
jalafer wrote:
FlipsidE
You might do better with this test if you set the camera and tripod so that the camera is facing the wall at a 45 degree angle. Then set the lens to AF and shoot a couple of frames. This way, you'll be able to better see if the camera is back or front focusing or if the lens is just soft to begin with.
...Leo
jalafer
Joined Dec 2003
Nov 19, 2004 09:01 |  #10
You might do better with this test if you set the camera and tripod so that the camera is facing the wall at a 45 degree angle. Then set the lens to AF and shoot a couple of frames. This way, you'll be able to better see if the camera is back or front focusing or if the lens is just soft to begin with.[/QUOTE]
In my opinion is better if you face the wall direct. If your lens is front focussing (as it happened with an old 70-210 in my case) you will realise inmediately because the MF picture will be well focussed.
Of course if you do it at 45º and put a mark on the paper to be foussing at, the you can see is your camera is front or back focussing.
transcend
Joined Oct 2004
Nov 19, 2004 11:48 |  #11
I will be using the focusing chart i printed out online, and the camera at a 45 deg angle. Trying to see what it is doing. If it is front focusing, i take it it is a simple enough calibration at a canon service center? Any idea on cost?
lmelendez
Joined Dec 2002
Nov 19, 2004 11:51 |  #12
If you suspect that your camera is back focusing... what do you do? you just use MF all the time ?! ?
How can you calibrate that?
http://www.bluejaygall​ery.com (external link)
robertwgross
Joined Nov 2002
Nov 19, 2004 12:23 |  #13
You can't, but Canon can.
A focus problem might be related to the camera body being out of spec, or it might be related to the lens being out of spec. Canon can test each piece independently, correct as necessary, and then put them together to make sure the combination is still right.
---Bob Gross---
transcend
Joined Oct 2004
Nov 19, 2004 12:57 |  #14
---Bob Gross---
yup, luckily there is a service center 20 mins form my house. I will take both in on monday.
transcend
Joined Oct 2004
Nov 19, 2004 13:53 |  #15
here is the result of the test.
Taken at 45 degs (as per marking on tripod, may be slightly off).
40mm, f 4.5, 3 foot distance aproximately. On 17-40L
I would assume that at 40mm/4.5 DOF would be pretty decent, would being off of 45deg even a tiny amount make the test worthless? It looks like it is back focusing a fair amount.
Also, as for the diopter, i just tested it and my manual focusing indoor in not so great light is not good. WAY off for now, i wear a fairly bizarre Rx pair of glasses tho (oddly shaped eyeball due to concussions). I matched it up so that AF looks sharp, when looking through it, but obviously this wont work if AF is off.,
this shot is from straight on
3,361 views & 0 likes for this thread, 9 members have posted to it.
1945 guests, 122 members online
