Thread started 11 Apr 2008 (Friday) 06:26
Canon 1.4x TCon reach example for newbies!
condyk
Africa's #1 Tour Guide
Apr 11, 2008 06:26 |  #1
Ok ... how much closer do you get with a 1.4x TCon? Maybe this quick pair of snaps will illustrate for y'all and help decide if you wanna invest!
IMAGE: http://www.buzzdns.com/TConNo.jpg
IMAGE: http://www.buzzdns.com/TConYes.jpg
https://photography-on-the.net …/showthread.php​?t=1203740
Nick ­ Pro
Apr 11, 2008 06:35 |  #2
What lens?
aridan
Gallery: 15 photos
Joined Dec 2003
Apr 11, 2008 06:38 |  #3
That's not an optimal example. The average user who needs a TC, gets it for outdoors reach. A x1.4 magnification on an object that is 10ft away from you is not the same as an object that's 200 yards away...
5D Mark III | 135L | 24-70L | 580EXII | Flickr | Instagram (external link)
SkipD
Joined Dec 2002
Apr 11, 2008 06:42 |  #4
aridan wrote in post #5306127 (external link)
Why isn't it the same? The same math works for both situations.
Skip Douglas
condyk
Apr 11, 2008 06:50 |  #5
pro wrote in post #5306117 (external link)
What lens?
70-200mm IS L 4.0 and just took the two shots at around 110mm point and shoot style.
Go ahead then ;-)a
SkipD wrote in post #5306136 (external link)
Exactly ;-)a
aridan
Gallery: 15 photos
Joined Dec 2003
Apr 11, 2008 07:06 |  #6
Of course the math is the same. The visual result and the way our brains processes zoomed on distant objects is different however. Let me see if I can dig up a good example...
MannP
Apr 11, 2008 07:17 |  #7
Looks like a good and sufficient example to me. Thanks for posting this condyk.
https://photography-on-the.net/forum/showthre​ad.php?t=463218
aridan
Gallery: 15 photos
Joined Dec 2003
Apr 11, 2008 07:24 |  #8
Here is the "best" explanation I found online at this time:
Perspective
The meaning of perspective is difficult to be defined precisely. Because the image of a three-dimensional scene is two-dimensional, perspective is created by the relative size of similar objects (i.e., a distant object looks smaller than a nearby similar object), converging lines, and so on.
Normally, we use telephoto lenses to take images of distant subjects so that the desired portion of the scene is ``extracted'' from its surrounding environment. The distance between two objects looks shorter and hence the scene seems ``compressed'' (i.e., objects look like close to each other). We mentioned this in previous section. On the other hand, wide angle lenses are normally used to take wide area and ``exaggerate'' the nearby objects (i.e., they look like larger than their actual sizes).
The rest is here (along with some visual examples): Optical Zoom (external link)
Scroll down to the 6 wooded area pictures. Clearly, zooming on distant objects are perceived (re: perspective) as being magnified more than on near objects. The math is the same but our perspective is not. ;)
As for the OT: Take your cat out and shoot it again only this time, do it from 100 yards away. :D
ScrewDrvr
Apr 11, 2008 07:58 |  #9
yeah, the closer you are to the subject, the more powerful your zoom seems.
Cyrusian
Apr 11, 2008 09:55 as a reply to  @ ScrewDrvr's post |  #10
Would be interested to see a crop of the original image to the same size as the second, to compare a crop v TC image...if at all possible.
a 400d, and very little knowledge :oops:
RowdyReptile
Apr 11, 2008 11:04 |  #11
condyk wrote in post #5306156 (external link)
I'd say this is a bad example because you could have just zoomed your lens from 110mm to 154mm for the same effect. The TC should really be used for extending the far range of a telephoto lens.
6D, 50D
24-105L, 50mm f/1.4, 100mm macro, 70-200 f/2.8L IS, Rokinon 8mm fisheye, 10-22mm, Speedlite 580EX II (2). Flickr (external link)
condyk
Apr 11, 2008 11:08 |  #12
Cyrusian wrote in post #5306989 (external link)
Don't be lazy ... ya can do that yourself ;-)a
RowdyReptile wrote in post #5307502 (external link)
:lol::lol: Wow man, thanks for the advice. I gotta remember I can 'zoom' my lenses.
JoYork
Apr 11, 2008 12:38 |  #13
In other news, walking forward one step will save you the cost of a Canon tc!
Just kidding :)
I would have given a better example though, try shooting something outdoors at 200mm and then the same object with the tc on.
Jo
condyk
Apr 11, 2008 12:39 |  #14
JoYork wrote in post #5308063 (external link)
Go on then ;-)a
JoYork
Apr 11, 2008 13:03 |  #15
If I had owned a teleconverter myself I would have given a better example...
:P
Jo
3,807 views & 0 likes for this thread, 11 members have posted to it.
1543 guests, 135 members online
