mot wrote in post #5316281
Best Price --> SD750, SD1000
4X optical Zoom -->SD850, SD870
3" LCD Display --> SD750, SD870
RAW support -->SD870, SD950
12 MP --> SD950
see comparison
here
Not the whole story -- no Canon SD has native RAW support. It's only through the CHDK hack. Some sites have reported RAW support for SDs, but it's just not true. You have to understand how to do the hack, be willing to work with a parallel menu structure, and be willing to work w/tools that read crw files (many tools do not). So, unless you are technical, I'd steer clear. If RAW support is important for you, then look at the G9, though it's a bigger camera. For casual snaps, RAW isn't needed.
850 and 870 both have 4X zoom (actually, 3.8 zoom), but the 870 is from a base of 28mm equivalent. So, the 870 has more wide angle (better for group and landscape shots) but less reach (for getting up close), than the 850.
If you want price, SD750 is a better camera than the SD1000. SD870 is the best overall from that list, excepting maybe the SD950 (which I haven't worked with, so I couldn't judge).
If you like the SD900, you probably won't go wrong with the 750, 870 or 950, but I use the SD800 constantly, and that wide angle sure is sweet. I'd be wary of 12MP on such a tiny sensor (the 950) which can lead to more image noise.
6D: 50, 85, 28-75, 70-210USM, 430EXii.
EOS-M: 22, 18-55
