Thread started 12 Apr 2008 (Saturday) 23:41
DIY Diffuser-Reflector for Hot-Shoe Flash
SYS
Gallery: 601 photos
Joined Jul 2004
Apr 12, 2008 23:41 |  #1
Again, nothing's new under the sun... My DIY is just some modifications of Chuck Gardner's here:
http://super.nova.org/​DPR/DIY01/ (external link)
Mine is only significantly different in that I added "cross-stitch matrix grid," "metallic silver", and upcoming "gold," reflectors that are easily interchangeable by velcro inside the "white" default reflector. Other minor differences are that instead of stapling around the edges, I used velcro to connect the inner white to outer black "fun foam," and used an iPod "exercise band" that is useless for my iPod use but perfect for this DIY. (I never throw away such "useless" things since you never know what DIY projects might come up. ;))
1) Diffuser-Reflector on Flash - Front View with "Cross-Stitch Matrix Grid." (Note that the top can bounce off its own "roof" which is useful when shooting in situations where there's no ceiling to bounce off of, as in outdoors or indoors with unreachable ceiling. When ceiling is available, the top can be angle-adjusted to open up towards the ceiling.)
2) Diffuser-Reflector on Flash - Back View
-Goethe
SYS
Gallery: 601 photos
Joined Jul 2004
Apr 12, 2008 23:42 |  #2
3) Side View
4) In Action
-Goethe
SYS
Gallery: 601 photos
Joined Jul 2004
Apr 12, 2008 23:45 |  #3
5) Back View with the iPod "exercise band" (Notice the two separate velcro on each side for angle adjustment. Being able to lay it flat is a big plus for portability.)
6) Front View with the "matrix grid" insert. Chuck Gardner's version uses this cross-stitch matrix as a stiffner between the white and black fun foam and therefore hidden inside. I decided, however, to give it a try as a reflector in itself as an experiment. With the "matrix grid" off, you'll have the white default reflector...
-Goethe
SYS
Gallery: 601 photos
Joined Jul 2004
Apr 12, 2008 23:47 |  #4
7) With "metallic silver" insert. (The "gold" reflector insert to come...)
-Goethe
SYS
Gallery: 601 photos
Joined Jul 2004
Apr 13, 2008 00:14 |  #5
So, do you think this cheap DIY (around $4 in all) can compete with the likes of Sto Fen, or Gary Fong Lightsphere, or.... ? :cool:
-Goethe
gorby
Apr 13, 2008 00:35 |  #6
awesome sample shots and everything
i wonder if the straight bounced doesn't look the best though, even though your sample turned out a little 'hot' i think (along with few of the others)
5D MKII | 650D [SIZE=2][SIZE=2][SIZE=​1]| 350D (RIP)
17-40 f/4L | 70-200 f/4L | 50mm 1.8 | 18-135 STM IS
My work (external link)
SYS
Gallery: 601 photos
Joined Jul 2004
Apr 13, 2008 00:49 |  #7
gorby wrote in post #5317591 (external link)
Thanks. The reason why I stated earlier that I need a better controlled testing is precisely because I don't know (yet) which type of situation is better with which kind of shooting methods (i.e., "roof" down for straight shooting, or open angle for bouncing off ceiling), as well as which type "reflectors" go better with which situation. So I got a lot of testing coming up... But one thing I feel very confident is that this thingy is working effectively as designed.
-Goethe
gorby
Apr 13, 2008 00:58 |  #8
Please do... and let us know how it goes.
Out of the modifier samples I'm liking the silver reflector one the best
SYS
Gallery: 601 photos
Joined Jul 2004
Apr 13, 2008 01:07 |  #9
gorby wrote in post #5317694 (external link)
As for me, from the limited modifier samples, it's a toss up between the silver reflector and the cross-stitch matrix grid. I'm sure more refined testings in the coming days and weeks with different applications would provide more insights.
-Goethe
gorby
Apr 13, 2008 01:11 |  #10
Despite some differences in the shadows (which are hard to gauge, as mentioned, being an 'uncontrolled' test with moving subjects), it also appears the reflective silver retains the best color rendition.
I suppose the samples bouncing off white have a cooler cast to them. In fact the silver reflector version is the closest to the bare flash in this regard.
MikeMcL
Apr 13, 2008 01:12 |  #11
The Metallic silver shot seems to be the most natural and contrasty image. the others dont seem to be lit at the correct ratio.
Very cool project, I might have to give one a try.
350d, 5d, 28-70L, 70-200L, 430EX,
50 1.8, 85 1.8 - full alienbees studio set.
MikeMcLane.comexternal link
SYS
Gallery: 601 photos
Joined Jul 2004
Apr 13, 2008 01:20 |  #12
I just noticed a shadow off the face of my son on the left of the image in the matrix grid reflector. I also did have a perception that the metallic silver reflector had the most natural and contrasty feel to the image.
Hey, for about $4 and an hour of time for the project, what have you got to lose? ;)
-Goethe
hdayanan
Aug 01, 2008 15:13 as a reply to  @ SYS's post |  #13
what material is the silver reflector, something I can buy at local stores..?
best regards
dan
SYS
Gallery: 601 photos
Joined Jul 2004
Aug 01, 2008 19:33 |  #14
hdayanan wrote in post #6028139 (external link)
best regards
dan
First, welcome to the forum! :)
The silver reflector that you saw on this thread is just an aluminum foil that you probably have in your own kitchen. However, I changed it to a more lasting foil tape that you can get easily from any Home Depot, Lowe's, or WalMart. Both do the same job, but I found that an aluminum foil from my kitchen tends to tear easily, so the change.
-Goethe
SYS
Gallery: 601 photos
Joined Jul 2004
Mar 02, 2009 17:44 |  #15
Here are the updated "silver insert" images and the latest sample photo... Please note that I've gotten rid of the original sample photos as they were poorly executed samples...
With HVAC foil tape: http://www.lowes.com …0999-133-40999&lpage=none (external link)
IMAGE: http://farm4.static.flickr.com/3593/3321072465_ed9035a748_o.jpg
With the "ceiling" in vertical position for bouncing...
IMAGE: http://farm4.static.flickr.com/3293/3321072311_5edf599a60_o.jpg
Latest sample shot...
IMAGE: http://farm4.static.flickr.com/3630/3321072493_82bcd19a3f_o.jpg
-Goethe
27,468 views & 0 likes for this thread, 21 members have posted to it.
Latest registered member is doubleUV
1051 guests, 191 members online
