This post is marked as spam.
BikerFox Member 43 posts Joined Nov 2004 More info | Nov 20, 2004 23:10 | #1 Permanent banSPAM PUT AWAY This post is marked as spam. |
robertwgross Cream of the Crop 9,462 posts Likes: 3 Joined Nov 2002 Location: California More info | Nov 20, 2004 23:25 | #2 BikerFox wrote: Any ideas? First of all, what camera were you using?
Olegis Goldmember 2,073 posts Likes: 2 Joined Apr 2004 Location: Israel More info | Nov 20, 2004 23:48 | #3 That's why you should use shoot in RAW - this lets you to correct the white balance after the photo was taken. Best wishes,
scottbergerphoto Cream of the Crop 5,429 posts Likes: 1 Joined Jun 2003 Location: Brooklyn, NY, USA More info | Nov 21, 2004 05:51 | #4 I agree that it sounds like you shot for daylight in tungsten lighting. If you didn't shoot Raw, you can fix it in a photo editor. In PS CS or PSE open up the image and then use Levels. Click on the Grey eyedropper. Then click on grey or a neutral color. That should help reduce the reddish yellow cast. One World, One Voice Against Terror,
Nov 21, 2004 14:46 | #5 Permanent banSPAM PUT AWAY This post is marked as spam. |
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Nov 21, 2004 14:50 | #6 Did they maybe have sodium (high intensity sodium's almost white to the eye) in the arena? I'd try using the white stripe on the one pair of trunks and the Armstrong pad on the post as your "white" settings using the method Scott described above (dropper). Jon
Nov 21, 2004 19:25 | #7 Permanent banSPAM PUT AWAY This post is marked as spam. |
AdamHicks Senior Member 952 posts Joined Apr 2004 Location: Ft. Worth, TX More info | Nov 21, 2004 19:35 | #8 Looks a whole lot better!
mdude85 Senior Member 391 posts Joined Jul 2004 More info | Nov 21, 2004 19:43 | #9 yeah, I thought this was boxing?
Nov 21, 2004 20:17 | #10 Permanent banSPAM PUT AWAY This post is marked as spam. |
wolf Senior Member 738 posts Joined Sep 2004 Location: Alberta Canada More info | Nov 21, 2004 21:24 | #11 Have you tried using the Color Cast correction then Levels?
Nov 21, 2004 21:42 | #12 Permanent banSPAM PUT AWAY This post is marked as spam. |
wolf Senior Member 738 posts Joined Sep 2004 Location: Alberta Canada More info | Nov 21, 2004 22:35 | #13 Sorry, if you are using PS Elements you can use Color Cast, if not then you would have to use Levels in PhotoShop CS Etc.
DocFrankenstein Cream of the Crop 12,324 posts Likes: 13 Joined Apr 2004 Location: where the buffalo roam More info | Nov 21, 2004 22:46 | #14 A bit off topic... National Sarcasm Society. Like we need your support.
Nov 22, 2004 09:28 | #15 Permanent banSPAM PUT AWAY This post is marked as spam. |
| Latest registered member was a spammer, and banned as such! 2014 guests, 127 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
