Thread started 14 Apr 2008 (Monday) 19:21
Suggestions please...
geoawelch
Apr 14, 2008 19:21 |  #1
Good Evening all,
In scoping out a site for a wedding/reception, I took some shots in the reception hall to get an idea of the lighting. The good news is that there is a lot of white on walls and ceilings; the bad news is a tremendous amount of dark wood.
I am looking for suggestions at how to rectify the photo shown below. I bounced the flash off the ceiling. As you can clearly see, the fully set white top of the table is completely blown out while the rest of the image is relatively okay.
Would a lightstand mounted flash in a discreet corner help? Another problem is the reception will be going on simultaneously in three rooms total. The head table will be positioned where the two gentlemen are in the photo. As always, thanks for your two cents.
George
George
NH
_____________
showngo
Apr 14, 2008 20:50 |  #2
You can probably get away with a lower flash power, have you tried dialing it down?
Ben
My Gear (external link)
Wilt
Apr 14, 2008 20:52 |  #3
I bet you had your flash pointed straight up, rather than pointing it upwards at a 45-60 degree angle...
QX56
Apr 14, 2008 22:20 |  #4
Try to angle your flash like Wilt said .
1D MK III,40D,G12.1Ds mk3.
24-70L,100-400L ,70-200F2.8LIS,85L,180L macro.18-200EF-S.8-15mmL.
Raynox DCR250,Kenko set extesion tube,ST-E2.
28-200,75-300,KenKo 2X TC,430EX,580EX II,Metz45 CL1.
NZDoug
"old fashion"
Location: French Bay, on the shores of the mighty Manukau Harbour, Aoteoroa
Apr 14, 2008 22:37 |  #5
What they said and the table will have colorful stuff on it so things wont be so stark or empty. Smart move to do this test.
HEY! HO!
LETS GO!
geoawelch
Apr 15, 2008 20:13 as a reply to  @ NZDoug's post |  #6
The flash was at either 1/4 or half power. It wasn't pointed directly up, but I don't think it was at 45 degrees. Thanks for the suggestions.
George
NH
_____________
872 views & 0 likes for this thread, 5 members have posted to it.
1469 guests, 132 members online
