Would like to know which way to go. The choice is the 400 f2.8 with converters as opposed to the 500 f4.
Has anyone evaluated the merits of either?
CaptainPete Member 41 posts Joined Jul 2007 Location: Dublin More info | Apr 16, 2008 05:34 | #1 Would like to know which way to go. The choice is the 400 f2.8 with converters as opposed to the 500 f4.
THETROOPER Senior Member 737 posts Joined Nov 2007 Location: Wales,U.K More info | Apr 16, 2008 07:42 | #2 Well, just because there has been so many views and no replys, i wiil say what i would do. 5DII GRIPPED - 17-40L
tiha Senior Member 960 posts Likes: 24 Joined Feb 2005 Location: 44°49′14″N 20°27′44″E More info | 400 mm f/2.8 L IS is heavier and more expensive. If you plan to rarely use 400mm focal length, go for 500mm f/4 L IS. EOS 5D, EOS 30D, EOS 3, PowerShot G6
gasrocks Cream of the Crop 13,432 posts Likes: 2 Joined Mar 2005 Location: Portage, Wisconsin USA More info | Apr 16, 2008 08:19 | #4 The 400/2.8 is mostly a sports lens used from a tripod or maybe a monopod. The 500/4 is for wildlife, birds and such. Can be handheld. Big difference in price as well. GEAR LIST
LBaldwin Goldmember 4,490 posts Likes: 4 Joined Mar 2006 Location: San Jose,CA More info | Apr 16, 2008 08:34 | #5 I have used both and went with the 400. The 500 is actually too light in windy situations where you want to shoot hand held. Alot depends on the subjects you intend to shoot too. If it is birds each lens has its advantages and draw backs. The 400 w/ the 1.4 is longer than the 500 at the same f/stop. But it has greater mass and is not the easiest to wheel around and track in flight shots. Les Baldwin
MarkEvan Senior Member 883 posts Joined Oct 2006 More info | Depends what you wan`t to shoot, if its sports then go for the 400 as previously stated its a great lens for that type of photography. If you plan on shooting wildlife then go for the 500, as has already been said the weight of the 500 is enough to hand hold for periods.........also if you shoot wildlife especially small animals the 500 with TC`s gives more length than the 400 with TC`s...............a bit obvious I know but reach is king when shooting small animals.
bobbyz Cream of the Crop 20,506 posts Likes: 3479 Joined Nov 2007 Location: Bay Area, CA More info | Apr 16, 2008 09:28 | #7 If more sports and less wildlife, then 400mm f2.8 IS. If other way around, then 500mm f4 IS. Fuji XT-1, 18-55mm
cwphoto Go ahead, make my day 2,167 posts Gallery: 30 photos Likes: 76 Joined Oct 2005 Location: Kellyville, Baulkham Hills, Cumberland, NSW, Australia More info | I examined the merits of each and decided to buy both. EOS-1D X Mark II| EOS 5D Mark IV | EOS 80D | EOS-1V HS
| Latest registered member is ANebinger 1149 guests, 175 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
