Hello...I have a quick question for other ST-E2 owners out there.
The background:
- As I was investigating the purchase of the ST-E2, I was under the impression that full ETTL capabilities would be retained.
- I purchased a used ST-E2.
- I am using the ST-E2 in conjunction with my Sigma DG-500 Super flashes.
- The Sigmas work fine when connected through my Off Camera Chord II.
The situation:
When I use the ST-E2, it fires the flash as I would have expected it to, but the flash does not get the ETTL information. IE...when I change the zoom on the camera, it is not reflected on the flash. So a 70mm zoom fires the flash thinking it is a 28mm zoom...and washout ensues.
The question:
- When you are using the ST-E2 with your 550s, 580s, 420s, etc...do they function as if they were connected directly to the hotshoe (or via an OCC)?
- Does anyone use the ST-E2 with a Sigma setup and get it to work properly?
Thanks for your assistance.
