Thread started 17 Apr 2008 (Thursday) 11:39
Buying a home studio today!
steve215
Apr 17, 2008 11:39 |  #1
So after a month or so of research and asking silly questions i have finally decided to purchase the calumet genesis 400 2-light kit.
http://www.calumetphot​o.com/item/CF0514K1/ (external link)
I will also be buying their heavy duty background support
http://www.calumetphot​o.com/item/MF6095/ (external link)
And to go on the background support
http://www.calumetphot​o.com/item/CS2728/ (external link)
http://www.calumetphot​o.com/item/CS2744/ (external link)
Also I will be buying the sekonic L-358
http://www.calumetphot​o.com/item/SE4052/ (external link)
I was also thinking about getting this
http://www.calumetphot​o.com/item/CF0044/ (external link)
I still haven't quite figured out the whole remote flash trigger but I guess I will figure it out. Without using pocket wizards how does one remotely trigger the flash with the light meter and camera. I did about a half hour of searching last night to no avail. Any guidance would be greatly appreciated. :)
I'm pretty excited about this!
-Steve C
40d EF-S 18-55mm f/3.5-5.6 IS | EF 70-300mm f/4-5.6 IS | EF 50mm f/1.8 II
http://www.myspace.com​/cirillo215 (external link)
:D
magicmikey
Apr 17, 2008 11:59 |  #2
steve215 wrote in post #5348607 (external link)
I bought a set of inexpensive Chinese remote triggers for my White Lightnings. A set comes with a trigger and receiver. I bought an extra trigger to take care of the light meter reading.
Here's the setup. One trigger on the camera hot shoe, one receiver on a strobe and the second trigger I hold in my hand with the meter. I set the meter to read and trigger the strobes with the test button on the trigger in my hand. It's pretty low tech but it works well and was way less expensive than PocketWizards.
I actually have two triggers and four receivers in case I'm in a situation where someone else could trigger the slaves on my strobes.
To this point, I've had no real problems with my inexpensive remote trigger system. I tested the batteries in the triggers and found them to be a little weak so I replaced them and the triggers have been very consistent.
These are the ones I use:
http://cgi.ebay.com …ZWDVWQQrdZ1QQcm​dZViewItem (external link)
The seller is out of New York so you don't have to ship overseas if you have a return. (I did get one receiver replaced. It was working fine but the insulation on the wiring didn't extend completely into the stress relief collar.
Michael
steve215
Apr 17, 2008 12:12 |  #3
thanks for the reply macigmikey
Are the triggers that you posted similar to this?
-Steve C
:D
tetrode
I am a walking repository of thoroughly useless information
Apr 17, 2008 13:03 |  #4
Congratulations, Steve. Sounds like a great setup. I have the Genesis 200 kit and it has been a pleasure to work with (despite some teething pains). Just one thing: If you're ordering these goodies online, don't forget the 5% cash back available if the order is placed through Jellyfish.com. That should be about $55; enough to buy yourself the Pocket Wizard radio module for the Sekonic meter!
Dave F.
magicmikey
Apr 17, 2008 13:09 |  #5
steve215 wrote in post #5348802 (external link)
Yes, except the receivers on the Calumet strobes use AA batteries when the ones I bought have to be plugged in. (It's not a big deal because it's a pass-through connection. You connect the receiver to the AC jack on the strobe, then you plug the regular strobe AC cord into the receiver and into the outlet.)
I like the idea of not having to have AA batteries for my receivers. That's one less thing to worry about.
Michael
Big ­ Mike
Apr 17, 2008 13:20 |  #6
I bought a set of inexpensive Chinese remote triggers for my White Lightnings. A set comes with a trigger and receiver. I bought an extra receiver to take care of the light meter reading.
I think you meant that you got an extra trigger for the light meter.
Just so everything is clear. :D
Instructor at The Canadian Photography Learning Centre (external link).
Blog (external link)
magicmikey
Apr 17, 2008 13:45 |  #7
Thanks, Big Mike. You are correct and I have edited my original post!
Michael
steve215
Apr 17, 2008 14:36 |  #8
I just went down to calumet and picked up all the stuff listed in my op. (except the trigger, they had to order it from santa barbra) I'm very excited to set it up!
I'll be back in a little bit with some pictures of the set up!
-Steve C
:D
steve215
Apr 17, 2008 16:58 |  #9
I've got it all set up and it works great!
I'm not sure though how to trigger the flash when using the light meter.
-Steve C
:D
richfell
Apr 17, 2008 17:48 |  #10
You've got a L-358 right? See page 15 of the manual and it shows you how to trigger a light with the meter using the PC cord(s) that came with your Genesis kit.
Rich
magicmikey
Apr 17, 2008 20:23 |  #11
hudge wrote in post #5350778 (external link)
That is true. It didn't occur to me to check if the OP was aware of that! That is definitely the least expensive route, although I do like my cheap remote trigger system.
Michael
steve215
Apr 17, 2008 20:43 |  #12
thank you sir! I am at school now so when i get home I'll go ahead and consult the manual. I took a quick look at the little cheat sheet they provide but it didn't mention anything. Anyways thanks for the advice!
By the way, this is so freakn' cool!!!!!:cool:
-Steve C
:D
richfell
Apr 17, 2008 20:55 |  #13
steve215 wrote in post #5351764 (external link)
Excellent, I know you will find that it is very easy.
Agreed! :) (I've got the Genesis 200 2 lite kit myself)
Rich
richfell
Apr 17, 2008 21:05 |  #14
magicmikey wrote in post #5351650 (external link)
Michael
Hi Michael, I've got the 16 channel version of the "eBay triggers" and I see that there are two ways to to trigger the lights:
1) Do exactly as you are doing :D
2) Hook up the transmitter to the L-358 via the supplied 12" PC-to-3.5mm cord and use the meter in corded mode to trigger the strobe
So far both ways have worked for me. I mentioned the corded mode to the OP because I saw in an earlier post that he didn't get his wireless triggers yet.
Rich
steve215
Apr 17, 2008 21:07 |  #15
I had a buddy come over right before I had to leave for school and he was dumbfounded at the set up. He's like "what the #$%$"
(none photo guy)
-Steve C
:D
2,819 views & 0 likes for this thread, 5 members have posted to it.
Latest registered member is DragonPhotos
1034 guests, 172 members online
