Thread started 17 Apr 2008 (Thursday) 18:07
Vignetting on a Sigma 10-20
C.Steele
Apr 17, 2008 18:07 |  #1
Is this normal at 10mm? I just bought a Sigma 10-20 and notice quite a bit of vignetting at 10mm. I have never used a lens this wide before, but I read a ton of reviews and none mentioned this. Maybe it's just a given? The lens is sharp and works well, but noticeably lighter in the middle. Just wondering if I got a questionable copy. Just new buyers panic I guess.
Chris
Sometimes I do get to places just when God's ready to have somebody click the shutter. -Ansel Adams
Portland Wedding Photographers (external link) | Steele Photography (external link)
Bendel
Apr 17, 2008 18:27 |  #2
Can you post a sample picture?
Brandon
Canon 5D, 24-105 F4L, 70-200 F4L, 85 F1.8, 430EX II
05Xrunner
Goldmember, Flipflopper.
Gallery: 52 photos
Apr 17, 2008 18:39 as a reply to  @ Bendel's post |  #3
what camera are you using it on.
Its made for the 1.6x crop cameras
on my 30D there was no vignetting at 10mm
on my 1DMKII I can use it from 11mm-20mm with no vignetting
on a 5D or 1Ds forget it
My gear
Fuji X-T2, Fringer Pro EF-X, 14 f2.8, 18-55 2.8-4 OIS, 35 f2, 50 f2, 90 f2, 55-200 3.5-4.8 OIS, Tamron 150-600 G2 VC
Sony RX100 II
Kruzkal
Apr 17, 2008 18:46 |  #4
Vignetting is normal for ultra wide lenses wide open.
http://www.photozone.d​e …st-report--review?start=1 (external link)
canadianbacon52
Apr 17, 2008 18:50 |  #5
To be honest I never noticed it, obvious question, but are you using any filters? Some filters (not all) will cause vignetting..
05Xrunner
Gallery: 52 photos
Apr 17, 2008 18:52 as a reply to  @ canadianbacon52's post |  #6
same here..I never noticed anything wide open at 10mm on a 1.6x
even with a slim CPL it never vignette
My gear
Sony RX100 II
acorean
Apr 17, 2008 19:01 |  #7
I haven't noticed anything vignetting on my Wigma. A polarizer will give you uneven skies. Stacking filters will most definitely give you vignetting.
-C
canotographer
Apr 17, 2008 19:08 |  #8
no vignetting on mine...
Mark
Camera : EOS 5D EOS 30D EOS Rebel 2000
Lens: EF70-200/2.8L IS EF100-400/4.5-5.6L IS EF 24-105/4L IS EF [COLOR=purple]17-40/4L EF-S 17-55/2.8IS [COLOR=#800080]EF 50/1.4
Accessory : 580EXII | BG-E4 | LSP| Extreme III 17GB
Crumpler: Keystone | Whickey & Cox | Barney Rustle+ Bucket
macropod
Apr 17, 2008 21:36 |  #9
Light fall-off on ultra-wide lenses is quite normal. According to canon EF Lens Work, the cos4 law:
states that light fall-off in peripheral areas of the image increases as the angle of view increases, even if the lens is completely free of vignetting. The peripheral image is formed by groups of light rays entering the lens at a certain angle with respect to the optical axis, and the amount of light fall-off is proportional to the cosine of that angle raised to the fourth power. As this is a law of physics, it cannot be avoided. However, with wideangle lenses having a large angle of view, decreases in peripheral illumination can be prevented by increasing the lens’ aperture efficiency (ratio of the area of the on-axis entrance pupil to the area of the off-axis entrance pupil).
For a lens with a 90 degreee FoV, the cos4 law dictates that the amount of light reaching the corners of the film/sensor is only a quarter the intensity of the light in the center. Depending on how succesful the manufacturer is at increasing the aperture efficiency while keeping everything else under control, the amount of light fall-off might be less. To see how the Sigma fares in comparison to a range of other lenses, go to:
http://www.slrgear.com …ct.php/product/​171/cat/31 (external link)
Cheers
MinisterStanley
Joined Dec 2004
Apr 17, 2008 21:39 |  #10
When I owned this lens (on my 20D) I never noticed any at all even wide open.
-Prodigal Son
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Apr 17, 2008 22:54 |  #11
Is the hood on properly? Do you have more than one filter on?
I've not noticed any significant vignetting on mine.
Gallery: http://tomyi.smugmug.c​om/ (external link)
Roy ­ Webber
Location: Corralejo, Fuerteventura....Canary Islands Spain
Apr 18, 2008 00:44 |  #12
No Problems with my Canon 10-22
Canon 7D, 40D,100-400 IS L, EFS 15-85 IS, EFS 10-22-With Faulty USM, 055XPROB+488RC2, 430 & 580 II Flash, Tokina 11-16mm f/2.8-:cool:
Photos (external link)
C.Steele
Apr 18, 2008 01:13 as a reply to  @ Roy Webber's post |  #13
This is an image SoC - 10mm wide open @ F4
Oops, that was F8, this is F4
Tee ­ Why
"Monkey's uncle"
Joined Feb 2006
Apr 18, 2008 01:17 |  #14
Yup a small amount of vignetting, not unusual for any lens to have.
C.Steele
Apr 18, 2008 01:28 as a reply to  @ Tee Why's post |  #15
So that looks totally normal and acceptable? I have never noticed it on my other lenses, but then again I've never had one this wide either. I personally don't find it bad and it could be delt with very easily in LR if need be. I just want to make sure that this is normal for this lens and I don't have a bad copy. It's sharp as heck, that's for sure:)
Thanks for the responses.
Chris
2,326 views & 0 likes for this thread, 12 members have posted to it.
1118 guests, 120 members online
