Thread started 18 Apr 2008 (Friday) 16:36
Cleaning - different subject (not sensor)
Kevin034
Apr 18, 2008 16:36 |  #1
How do you guys clean the mirror that reflects the image to the view finder? As far as I know, it's just a standard mirror, no coating or anything.
Kevin
MKIII/5D/24-70/70-200/50
Bill ­ Roberts
revolting peasant
Apr 18, 2008 17:07 |  #2
Not quite true Kevin. The silvered coating is on the front rather than the back which makes it quite easy to scratch. It's not impossible to clean but go VERY carefully! Most people would advise leaving well alone.
cheers
BiLL
gjl711
Apr 18, 2008 17:13 |  #3
There is another thread discussing this exact same thing. Check out:
https://photography-on-the.net/forum/showthre​ad.php?t=487492
Basically some people are comfortable cleaning it the same way as you do your sensor but apply less pressure, and others believe it will shatter and crumble to dust if looked at, and then there are those everywhere in between.
I just clean mine like I do my sensor and it's worked for me.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
Kevin034
Apr 18, 2008 17:20 |  #4
hm ... there's a silvered coating on it? Anyways, the other night I saw some finger prints on it and I just wiped it off w/ a lens pen. It looks perfect now, under all lighting angles and I can't see any more spots in the view finder. Had no idea that it was that delicate.
Kevin
canonloader
Gallery: 6 photos
Apr 18, 2008 17:23 |  #5
I just skipped down here. I was afraid to read this thread past the word mirror. :lol:
Mitch- ____...^.^...____
Bill ­ Roberts
revolting peasant
Apr 18, 2008 17:26 |  #6
Hey... don't knock it :D it looks like you got away with it!
A lot of these things are hyped up out of all proportion, but you do have to be careful sometimes. The trouble is, that when it does go wrong it can be quite expensive to repair.
Glad it worked out ok!
cheers
BiLL
Kevin034
Apr 18, 2008 17:40 as a reply to  @ Bill Roberts's post |  #7
lol :D
Either way, the mirror surface is now perfect. I didn't use any chemicals, just a lens pen (which actually left some swirl marks (from the original finger print). I ended up using a lens cloth and just wiped it down lightly. :shock: :twisted:
Kevin
1,330 views & 0 likes for this thread, 4 members have posted to it.
1588 guests, 137 members online
