POTN forums are closing 31.12.2023. Please see https://photography-on-the.net/forum/showthread.php?t=1530921 and other posts in that thread for details.
Thread started 19 Apr 2008 (Saturday) 18:21
When you began using a hand held meter, did your exposure improve a lot?
slphotography
Apr 19, 2008 18:21 |  #1
I am thing about getting a hand held meter. I struggle with exposure occasionally. Do you think a hand held meter could help? Did it improve your exposure when you began using one? Thanks
~Stephanie
~Canon T6
SkipD
Joined Dec 2002
Apr 19, 2008 18:28 |  #2
slphotography wrote in post #5363526 (external link)
Since there were very few meters built into cameras when I started using a handheld meter, I would have to say that my answer is a resounding YES.
Joking aside - most currently produced handheld meters (that are worth buying) can make light measurements in two ways - measuring reflected light (that which reflects off your subject) and measuring incident light (that light which falls on your subject). The meters built into our cameras are only capable of measuring reflected light.
Many, if not most, handheld meters made today can also measure light from electronic flash sources. I don't know of any meters built into cameras that can measure light from flash sources such as studio flash lighting.
Thus, a handheld meter is far more versatile than meters built into today's cameras.
Skip Douglas
René ­ Damkot
Apr 20, 2008 09:37 |  #3
SkipD wrote in post #5363569 (external link)
Leica R8 and R9, and I think (not sure though) Contax RTS III ;)
I use a hand held meter for flash metering, so: Yes it is better then not metering ;)
For ambient metering: Not much difference; Read up a bit on how the light meter works, and learn to see a scene in "shades of gray"
The imageshere (external link) might help.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
nadtz
Apr 20, 2008 13:04 |  #4
I learned with a meter so the question is kind of moot, but when I started shooting again what I mainly noticed were
1) more consistent results
2) much faster setup
My fiancee and I did a 'messing around' shoot outside on a fairly brisk day last year a bit after I got my meter. Instead of setting up lights, taking test photo(s) tweaking lights, testing, tweaking... she was amazed when after the first test shot I was all "ok, lets go!" She had gotten used to me 'faffing about' which always annoyed her. After using the meter for a while I also find my eye is much more reliable so for 'quick and dirty stuff, which is rather nice.
Nuttcraker
Apr 20, 2008 13:28 |  #5
Definitely YES! Like nadtz said, the consistent results, much faster setup (when working with strobes) and accuracy.
It´s a must have if you want to have good results.
With enough light, you can turn a white wall black. (Master Strobist)
Gear List (external link)
1,069 views & 0 likes for this thread, 5 members have posted to it.
3523 guests, 116 members online
