Thread started 20 Apr 2008 (Sunday) 02:26
Getting background blur - Fundamental
ghosh
Apr 20, 2008 02:26 |  #1
So here I am back with another fundamental question.
I fix a 200mm 2.8 at a distance from the subject so that I get a X frame size image of the subject. My focusing ring on the lens shows 5 feet ( making a guess to illustrate my question). Now I shoot at 1/100, F2.8
I take another lens. This time 50mm. I place it at an appropriate distance from the subject so that I get the same X frame size image of the subject. My focusing ring on the lens shows that the subject is 5feet away. I shoot again with 1/60 and F2.8
Lets now forget the lens limitations. In actual world I should get the same DOF considering that both had the same aperture and focal length does not matter right???
Thanks..
#include <iostream>
int main() {
std::cout << "POTN is the best." << std::endl;
return 0; }
chauncey
Apr 20, 2008 02:49 |  #2
Go here http://www.dofmaster.c​om/custom.html (external link)
SkipD
Joined Dec 2002
Apr 20, 2008 04:36 |  #3
ghosh wrote in post #5365688 (external link)
Lets now forget the lens limitations. In actual world I should get the same DOF considering that both had the same aperture and focal length does not matter right???.
I do believe you are confused about something. If you are comparing shots taken with a 200mm lens and with a 50mm lens, they do NOT have the same focal length.
The 200mm and 50mm values are referring to focal lengths.
The distances between the camera and subject and the framing of the two shots have nothing whatsoever to do with the term "focal length".
Focal length is a physical characteristic of a lens. Some lenses have fixed focal lengths and some (zoom lenses) have variable focal lengths.
Skip Douglas
yogestee
Apr 20, 2008 05:25 |  #4
Thanks..
ghosh,,I think I know what you mean in a cryptic kind of way..If you fill your view finder with the subject using a 200mm lens @ F2.8 you get X amount of background blur..If you fill the frame with a 50mm lens @ F.2.8 you also get X amount of back ground blur..Are you asking which which situation gives you the most back ground blur??
The variable here is the focus distance,,both 5 feet..in this case the 200mm will give you more back ground blur but the image size will be larger..Back ground blur is relative to focal length, distance from the subject and aperture..
Am I on the right track??
Jurgen
SkipD
Joined Dec 2002
Apr 20, 2008 05:33 |  #5
After re-reading the original post, I feel that it's important to bring up another point.
It would be impossible to get the same ("X frame size image") framing of a subject with a 200mm lens and a 50mm lens from the same distance.
To keep the framing of the primary (foreground) subject the same, you'd have to be at roughly 1/4 the distance with the 50mm as you would with the 200mm lens. Note that the background material in the image would be radically smaller with the 50mm lens, though.
Skip Douglas
ghosh
Apr 20, 2008 06:36 |  #6
Thanks..
I am sorry, I typed wrong.
Let me make it simple.
at 200mm F4, I make a frame of the subject. Lets assume X frame.
Now I take another lens say a 50mm lens. Stand in appropriate distance from the subject so that I get the same X size frame as in the previous case. and use aperture F4.
Will the blur be the same in both frame?
In other words, keeping the aperture same. Keeping the frame same. Using different focal length lens. Standing away from the subject accordingly. How would it effect the blur?
This question came to my mind because I was thinking of buying a portrait lens. Now if the result from the above are same then why buy a long lens and stand far way? Use a small lens, stand close and get the same blur, isn't it? When I am only concern with DOF (as of now).
#include <iostream>
int main() {
return 0; }
SkipD
Joined Dec 2002
Apr 20, 2008 07:53 |  #7
ghosh wrote in post #5366258 (external link)
If you use the DOFMaster calculator (external link), you can work the DOF numbers....
200mm at 20 feet, f/4: 19.8 ft to 20.2 ft, .45 ft DOF
50mm at 5 feet, f/4: 4.79 ft to 5.23 ft, .45 ft DOF
While the calculated depth of field at the subject's plane is the same, there are some VERY significant differences in what you will see in the images.
As related to depth of field alone, the background will probably be more out of focus with the longer lens.
Because of the difference in distance between the camera and subject, there will be a significant difference in perspective. Perspective, in this sense, is defined as the relative sizes of foreground and background elements of the subject in the image. An experienced photographer will choose the distance between camera and subject as well as the focal length to control perspective.
Here's a simple example of how perspective control can work for you:
Let's assume that you are taking a photo of some friends in a scene that has mountains in the background. You stand 20 feet from the people and view the scene. A 50mm lens will let you fill the frame with the group of people and some of the background quite nicely, so you take a shot. Then you realize that the mountains are rather small in the background.
Back up to to 40 feet (twice the distance) from the group of people and view the scene, you will see that the mountains are now larger relative to the people - twice the size they were before, in fact. However, the people are smaller in your viewfinder. You now need a 100mm lens to keep the people the same size as in the first image, but the mountains now appear twice the size that they were in the first shot.
Why is this? It's because the additional twenty feet that you put between yourself and the people is insignificant relative to the fifteen miles between your viewing spot and the mountains.
When you are closer to subjects, perspective still comes into play. If you shoot a portrait from a location very close to the subject, the nearest objects (a nose, for example) will be larger relative to more distant objects (such as an ear) than they would appear from a greater distance. That is why experienced portrait photographers like to use a little more distance - and thus a little longer lens – than some beginning photographers would choose when shooting conventional portraits. The subject will usually be happier with the perspective achieved by the greater distance.
In other words, you don't normally want to be really close to a portrait subject if you have the option to back off a bit.
Skip Douglas
872 views & 0 likes for this thread, 4 members have posted to it.
2769 guests, 159 members online
