Thread started 24 Nov 2004 (Wednesday) 16:29
What mode can you set light/sun levels with w/Digital Rebel?
JasonMX
Nov 24, 2004 16:29 |  #1
I have been having some nature shots come out darker then they should, because of low light. What mode allows you to adjust the balance for different light levels?
Surf to http://blog.outphishin​g.com (external link) ----
1st Body: Canon Digital Rebel EOS XTI (400d)
2nd Body: Canon Digital Rebel EOS (300d)
Lenses: Canon 18-55mm AF, Quantary 70-300mm AF
Software: Adobe Photoshop Elements 4.0
commando
Joined Oct 2004
Nov 24, 2004 16:32 |  #2
I use the exposure lock - the * button. If it's still dark you probably need to use a longer exposure time.
JasonMX
Nov 24, 2004 16:50 |  #3
Yeah, it's not horribly dark or noticeable but I still would like them a little lighter. I will check in the book about exposure levels.
commando
Joined Oct 2004
Nov 24, 2004 17:14 |  #4
What mode are you shooting in (Av, manual, scene, etc)? Jpg or raw?
JasonMX
Nov 24, 2004 17:30 |  #5
I am in AV mode where I control the apeture.
commando
Joined Oct 2004
Nov 24, 2004 17:38 |  #6
The camera should be exposing it properly. Try pointing the centre of the viewfinder at what you want to be properly exposed, hit the * button, recompose, and take your shot. Let us know how that goes.
OviV
Joined Oct 2003
Nov 24, 2004 17:56 |  #7
If your shots are a bit underexposed try setting exposure compensation up a bit. Its in the manual.
5D, 40D, Sigma 12-24mm f/4.5-5.6 EX, Sigma 15MM Fisheye,17-40 L, 24-105 L, 50 1.8, Tamron 28-75 2.8, Sigma 70-200 2.8, 70-300mm f/4-5.6 IS, 100-400 L, 300 F4 L, 580 ex, Sigma 500 Super DG Flash x 2, too much other stuff to list.
Hellashot
Joined Sep 2004
Nov 24, 2004 18:25 |  #8
For the most part just about all of your Drebel images will probably come out darker than they would if they were taken on film. You'll need to do photo editing of all your images. That's what I do. If you want images that come out good without editing I hear the 20D does a lot better with images coming out how they should look without editing.
5D, Drebel, EOS-3, K1000
lenses from 12mm-500mm
leonid
Joined Dec 2003
Nov 26, 2004 09:37 |  #9
Whether you are shooting a very dark object or very bright object camera would set the exposure so that the object appears gray. Most of the time you don’t want your object appear gray unless it is really gray. And camera’s metering system has no idea what is the real brightness of your object.
In Av mode camera is using partial metering mode, when only central part of the frame is used for metering. I believe you have several options.
Option 1:Exposure lock *, as was advised above. But there is one very important consideration. The object you are chousing for exposure locking does not have to be the most important object. It does not even have to be part of the frame. It just has to be in the same lighting condition as the frame you intend to capture. And the most important it should be low contrast object, not too dark, not too bright.
Option 2: Exposure compensation. Take a shot, look at the histogram and then adjust exposure compensation. Of course, the exposure compensation is only valid, while you are shooting the same scene. When you move to shoot a different scene, you might have to find different setting for your exposure compensation.
Option 3: Exposure Bracketing. Choose the exposure bracketing range from the menu. On each scene fire 3 shots. Those three shots would have different exposures. Then you can choose the best one.
2,458 views & 0 likes for this thread, 5 members have posted to it.
1760 guests, 133 members online
