Awhile back my A70's LCD wouldn't show a display or record pictures, although it would display recorded pictures. I discovered that a slight twist of the body of the camera would correct the problem, but it would return occasionally. Last week, I turned on the camera and the display was black. No amount of twisting of the camera body would correct it.
I assume there's a loose connection inside the camera. Is this something I can fix myself or will I have to take it in to be repaired? Because it's an old camera, I can't help but wondering whether it's worth the expense. I like this camera because I have both wide-angle and telephoto lenses for it and am not sure whether I can buy a new camera with which these lenses be compatible.
Can anyone offer any suggestions? And if I should investigate getting it repaired, can you recommend an inexpensive/reliable mail-order repair service?
Thanks,
Bob
