Thread started 21 Apr 2008 (Monday) 12:10
Semi-Newbie Filter Question
ghostowl
Apr 21, 2008 12:10 |  #1
Hi Everyone!
I'm brand new to this forum, and so excited to have found it! I've got a Canon Digital Rebel and a Digital Rebel Xti that I just purchased. I have a question about neutral density filters versus circular polarizing filters. I have both. I know that the polarizer cuts down on reflection/glare, while the neutral density filter reduces light coming into the lens. I assume the polarizer also reduces light coming into the lens because of its dark color. Are the two basically interchangeable, or will the ND filter not remove glare from water surfaces the way the polarizer does?
Thanks,
Ghostowl
Canon EOS 300D w/ 18-55mm kit lens, EOS 400D w/ 15-55mm lit lens, Canon EF-S 55-250 mm f/4-5.6 IS, Canon 430 EX Speedlite, Cokin CP, Tiffen .6 ND, Sunpak UV
Cody21
Apr 21, 2008 12:17 |  #2
Correct ... the polarizing effect is different than the ND filter - which primarily just allows you to shoot in harsh light while at the same time bring the ability to step down on aperature, shutter, and ISO. You'll also probably find that you'll lose a stop or so of light using a CPL.
5DM3 | 16-35mm f/2.8L II USM | 70-200mm IS f/4L | 24-105 f/4L | Sigma 18-50mm f2.8 | Speedlite 430EX
argyle
Apr 21, 2008 13:03 |  #3
ghostowl wrote in post #5374137 (external link)
Thanks,
Ghostowl
They're interchangeable to the extent that, in a pinch, you can use the CPL as a 2-stop neutral density filter. A CPL can do what an ND filter can do, but an ND can't do what a CPL can do.
ghostowl
Apr 21, 2008 13:15 as a reply to  @ argyle's post |  #4
Thanks Cody & Argyle - that clears it up quite well!
Do either of you carry multiple ND filters? I bought the Tiffen .6 - but since on the digital I can step exposure down (if that is the right way of putting it), is it necessary?
Thanks again!
~G~
Cody21
Apr 21, 2008 13:21 |  #5
I only have 1 ND filter ... a 3x (3-stop). Where it comes in handy is when I want to shoot in very bright light but at the same time want to have a slow shutter speed (e.g., to capture the silkiness of a water fall). I actually want to get a GND so that I can better balance lighting between say a bright sky against a darker groound - to prevent a blown-out (overexposed) sky.
598 views & 0 likes for this thread, 3 members have posted to it.
2767 guests, 160 members online
