Thread started 22 Apr 2008 (Tuesday) 19:29
... and then, depression set in.
csquared63
Apr 22, 2008 19:29 |  #1
OK, is it me or my lens, or both. I'm leaning towards me and I'm disappointed I missed a great opportunity.
I spotted an osprey flying over a local pond. My 40D was in Av mode at f/4.5-5.6(100-400L) with the basic camera settings. I changed my focus mode to AI Servo. ISO was at 400. Shutter speeds of 1250, 800, and 3200 were used on these three shots. All shots are 100% crops. See full EXIF for all below photos.
In retrospect I should have switched to burst mode, but I didn't.
I want to improve. Is the trick blasting off as many shots as possible to get one good one, or trying to steady the lens and frame the shot—or both? (both, duh) I guess I learned something.
Or, does my lens appear to need repair?
1. Just after the "grab". He was relatively stationary at this point.
IMAGE: http://www.pbase.com/csquared63/image/96006954/original.jpg
2. He's circling now and I have multiple opportunities to get a good shot, despite the trees.
IMAGE: http://www.pbase.com/csquared63/image/96006955/original.jpg
3. Probably the best focused of the bunch (still not to the level I've seen with others' ... enter the tree!
IMAGE: http://www.pbase.com/csquared63/image/96006956/original.jpg
EXIF for #1
Camera Model Canon EOS 40D
Shooting Date/Time 4/22/2008 12:42:16 PM
Shooting Mode Aperture-Priority AE
Tv( Shutter Speed ) 1/1250
Av( Aperture Value ) 5.6
Metering Mode Evaluative Metering
Exposure Compensation 0
ISO Speed 400
Lens EF100-400mm f/4.5-5.6L IS USM
Focal Length 400.0 mm
Image Size 3888x2592
Image Quality Fine
Flash Off
White Balance Mode Auto
AF Mode AI Servo AF
Picture Style Standard
Sharpness 3
Contrast 0
Saturation 0
Color tone 0
Color Space sRGB
Long exposure noise reduction 0:Disable
High ISO speed noise reduction 0:Disable
Highlight tone priority 0:Disable
File Size 4723 KB
Drive Mode Single shooting
EXIF for #2
Shooting Date/Time 4/22/2008 12:42:24 PM
Tv( Shutter Speed ) 1/800
ISO Speed 400
Image Quality Fine
Flash Off
AF Mode AI Servo AF
Sharpness 3
Contrast 0
Saturation 0
Color tone 0
Color Space sRGB
File Size 3520 KB
EXIF for #3
Shooting Date/Time 4/22/2008 12:42:34 PM
Tv( Shutter Speed ) 1/3200
ISO Speed 400
Image Quality Fine
Flash Off
AF Mode AI Servo AF
Sharpness 3
Contrast 0
Saturation 0
Color tone 0
Color Space sRGB
File Size 3069 KB
-Carl
My Galleries (external link)
Skrim17
Apr 22, 2008 19:39 |  #2
You have goldfish in your local pond?
Crissa
csquared63
Apr 22, 2008 19:44 |  #3
Skrim17 wrote in post #5384123 (external link)
I'm sure it was introduced by someone. When I saw it with my naked eyes I thought it was just a 'goldfish' carp, but then I saw the fancy fins and I couldn't believe it. I'm assuming it's been living in the pond for a while. I'm not sure why someone would toss a fish like that. They're pretty expensive!
-Carl
canonloader
Gallery: 6 photos
Apr 22, 2008 19:47 |  #4
Well, you can't shoot a moving bird with One Shot. AI Focus would work though, and I had to use it with the 30D and Bigma. So you have to use AI Servo or AI Focus. However, the 40D has 4 or 5 Custom Function settings that will screw with the lens focusing in a way your not us to with earlier 10 series models. It's a cross between 30D and 1D stuff. :)
Also, don't forget, in AI Servo, the shutter will fire even if there is no focus lock.
Goldfish like that are a nickle apiece when they are dime size. :)
Mitch- ____...^.^...____
IraRunyan
Apr 22, 2008 19:51 |  #5
Am I understanding that you were trying to photograph the osprey with your lens wide open? If so, I would suggest that you try f8 to f11, that way you will have a deeper DOF and more of your shots will be in focus.
Canon 7D,Canon Rebel XTi, Canon 70-300mm f4-5.6 IS USM,Tamron 200-500mm
Please Visit my Photo Gallery http://ira-runyan.artistwebsites.​com/index.html (external link)
Florida Wildlife & Nature Photography (external link)
csquared63
Apr 22, 2008 19:54 |  #6
canonloader wrote in post #5384168 (external link)
I had AI Servo set.
I thought I was getting focus lock. I had the center spot active.
Not only that, but they're practically worth 5¢! ;-)a Thanks for the pointers, Mitch.
-Carl
csquared63
Apr 22, 2008 19:55 |  #7
IraRunyan wrote in post #5384197 (external link)
Good point, Ira. If I shoot f/8 to f/11 I'll lose shutter and need to crank ISO, right? I should have tried, but it was bright and sunny, so I thought I'd try to minimize any potential grain.
-Carl
cool ­ breeze
Apr 22, 2008 20:03 |  #8
All I can add is that I have a 400 F5.6L and it's focus is so fast I miss shots. With a fast focus if you slip off the bird for a fraction of time it will try to focus on the BG. In the first photo it seems the tree was coming into focus.
One other thing. I have a 70-300 IS that gave me shots like this when the IS was going up. You may try some test photos with the IS off. Still, or moving it would lock (out of focus). It never hurts to try.
Will
Canon 1D Mark3/ Canon 40D/ Canon XTI / EF400mm F5.6L USM / EF70-300mm F4-5.6 IS / EF600mm F4L NON IS USM/ 1.4 Canon TC
http://www.flickr.com/​photos/25831631@N03/ (external link)
Duane ­ N
Gallery: 198 photos
Apr 22, 2008 20:08 |  #9
cool breeze wrote in post #5384263 (external link)
I was going to ask if the IS was on or off in these photo's. Everything I've read says on in'flight to turn the IS off....if it was off ignore my reply.
www.3rdicreations.com (external link)
csquared63
Apr 22, 2008 20:11 |  #10
Duane N wrote in post #5384291 (external link)
It was on, mode 1. Thanks for the tips, Will and Duane!
-Carl
bromm
Apr 22, 2008 20:41 as a reply to  @ csquared63's post |  #11
If you dont mind Carl, when you save your photos use the "save as" tab, this keeps the exif(photodata) attached to your images, then we could read your shutterspeed etc, then we could guess a little more educatedly.. if thats a word ;).
I use the XT and the 400 5.6. AI servo, iso 400 with the sun behind me to get the best lighting. I use center point and have the * button on the back set for af and the shutter button set for the exposure lock. Are these big crops? how far away were you?
If you havent already, set your focus limiter switch to the longest distance, this will speed up the AF.
Trevor Wadman
Canon 40D/350D Canon 400L F/5.6, Canon 70-200L F/4 non IS. Tamron 100-300,Canon 18-55 Kit Lens. Canon 1.4 II Extender, Canon 430EX speedlight.
http://s41.photobucket​.com/albums/e286/bromm​/ (external link)
csquared63
Apr 22, 2008 21:00 |  #12
bromm wrote in post #5384513 (external link)
Hi Trevor, I am conditioned to using "Save for Web" since I do it daily at work—plus I like seeing the compression preview. I'll try to remember to "Save As" next time I post a question like this. See EXIF above in original post.
They are 100% crops and I was probably 300-750' away.
It was on 6.5m. I think maybe I just strayed too much while tracking with AI Servo.
Thanks for the tips.
-Carl
swampler
Apr 22, 2008 21:09 |  #13
csquared63 wrote in post #5384303 (external link)
You should use mode 2 for panning, or at those shutter speeds, you could turn it off, but no need to.
Steve
Permagrin
Apr 22, 2008 21:13 |  #14
I would have to disagree...I mostly shoot my bird shots wide open...F8-11 will only give more motion blur.
20D_Newbie
Apr 22, 2008 21:48 |  #15
I would turn the IS off. If you leave it on, it must be in Mode 2. Mode one will try to correct your panning motion and introduce blur. Mode 2 only corrects movement in the vertical so it does not try to correct the panning motion. Still, I would turn it off at those shutter speeds.
Canon EOS 7D with BG-E7 battery grip, EOS 40D with BG-E2 battery grip, Canon 20D, Canon EF 70-200mm F2.8L IS, Canon EF 24-70mm F2.8[COLOR=#ff0000]L, EF 300mm F4L IS, EF 400mm F5.6L, EF-S 17-40mm F4.0L, Canon Speedlite 580EX
2,284 views & 0 likes for this thread, 10 members have posted to it.
863 guests, 134 members online
