Thread started 22 Apr 2008 (Tuesday) 21:24
slave and speedlight?
Lemmonphotography
Apr 22, 2008 21:24 |  #1
ive been wondering what the best option for lighting it in terms of a slave flash and then also a speedlight
Does it work well to use these to together?
And what are some popular combos and stuff that you guys have used?
30d w/ BG-E2
200mm f/2.8L II
28-135 f/ 3.5-5.6
50mm f/1.4
aim: sweetndsour15
PhotosGuy
Moderator
Joined Feb 2004
Apr 23, 2008 09:01 |  #2
Used for what? If you don't have other people using flash, optical slaves work pretty well:
SL-2 optical slave: Look at post #10:
Simple "every-day-emergency" location lighting
Simple 2 Light Portrait Set-up
Lemmonphotography
Apr 23, 2008 18:37 |  #3
well i want lighting for two main reasons...one being i have lots of trouble shooting people outside and indoors because of the lighting, and if im not fighting for light, i always get terrible shadows. another main reason is for shooting at our local music venue that is rather dark, and all the musicians are not very shootable except the singer.
As of now i use my 50 without of flash, because the on cam one drives me crazy.
30d w/ BG-E2
200mm f/2.8L II
28-135 f/ 3.5-5.6
50mm f/1.4
aim: sweetndsour15
PhotosGuy
Moderator
Joined Feb 2004
Apr 24, 2008 08:41 |  #4
It's tough when you have no control over the situation. When you do, start with "good light": Angeline outdoors
Low cost off camera flash tutorial for beginners
If other people are using flash, then optical slaves aren't a good choice. Maybe an extension cord & having someone else hold the strobe is the cheap answer. Otherwise you'll need the radio triggers.
1,184 views & 0 likes for this thread
Latest registered member is DLKphotography
904 guests, 305 members online
