FORUMS Photo Sharing & Visual Enjoyment Macro
Thread started 23 Apr 2008 (Wednesday) 03:08
70-300 IS and our best settings...
MarkTH
Apr 23, 2008 03:08 |  #1
What settings ,Functions-settings-focusing, you generally use ?
and may advice while shooting, using this lens at macro at short distances i.e. grass, flowers,insects ?
Thank you.
PS (having 40D )
Canon: 5D MkII | 35 f/1,4 L | 100mm Macro f/2.8 IS L | 24-105mm f/4 IS L | 70-200mm f/4 L IS |...| 580 ExII, 430Ex Speedlite | Velbon Sherpa 750R | B+W MRC filters UV | Kenko Ext Tube | Epson P-5000 | LowePro backpack | 27" Dell | CS3 | LR2.4
My small PHOTO gallery (external link)
LordV
Apr 23, 2008 03:29 |  #2
Most of us use MF but they may not be necessary for closeups rather than Macro. For natural light shots use Tv or Av mode but if handheld obviously keep the shutter speed up via ISO. If using Flash then most will use M mode unless you want a fill flash effect. eg 1/200th ISO200, F11.flash in ettl.
Brian V.
Macro Hints and tips
MarkTH
Apr 23, 2008 03:42 as a reply to  @ LordV's post |  #3
Thank you for your advice / answer.
I generally use 75% of time Av mode - it is convenient for me to get what I expect
....but I wonder if maybe would be helpful any teleconwerter or similar additions.
What do you think about that ? /what do you recommend to buy to get (using this lens) the maximum sharpnes/ quality ?
Thanks in advance.
Mark.
LordV
Apr 23, 2008 03:52 |  #4
MarkTH wrote in post #5386448 (external link)
Thanks in advance.
Mark.
If you want more magnification then I'd get a set of Kenko extension tubes. At the short end you'd get 1:1 magnification with a full set on.
A TC will work and give better working distances than ext tubes but will degrade the IQ.
Brian V.
MarkTH
Apr 23, 2008 05:38 |  #5
Any recomended source for shopping, where you do ..... if I may ask ?
Kenko -..... is the model of Kenko extension tube you special recommend (I see there is only one type of them) ?
With what lens you use this Kenko ext tube ?
Thank you in advance and excuse me for so many questions :-)
LordV
Apr 23, 2008 06:42 |  #6
MarkTH wrote in post #5386693 (external link)
Can only suggest you either use one of the Hong Kong EBAY suppliers or perhaps one of the German WEB photographic shops.
The Kenko ext tubes I mean are a 3 tube set obviously EOS fit ones.
Brian V.
MarkTH
Apr 23, 2008 12:59 |  #7
The Kenko complete of 3 rings I've ordered today ;-)a
Honk-Kong is not good for me, because of additional costs: duty and tax while importing from outside of EU.
Thank You, Brian.
1,323 views & 0 likes for this thread
Latest registered member is quadrentau
2088 guests, 298 members online
