Thread started 23 Apr 2008 (Wednesday) 08:43
Main dial not responding
Molnies
Apr 23, 2008 08:43 |  #1
My main dial on my 350D just stopped working. It doesn't respond to anything, in any of the camera modes etc. I can't find any information about this problem and have never had a single problem with my camera before.
I'm not getting any error messages from the camera, the dial just isn't responding. I've taken out the batteries and I'm currently waiting to see if that will fix the problem, but I doubt it's that simple...
Does any one have any experiences with this? I tried searching on the forums but couldn't find any relevant threads... any and all help appreciated...
Thanks!
Fredrik — Portfolio (external link)
50D — 350D + BG-E3 — 100-400mm L IS — 100mm f/2.8 Macro — 50mm f/1.8 — EF-S 18-55mm — Tamron 90 f/2.8 Macro
Manfrotto 055ProB + 488RC2 — Speedlite 430EX — Sigma EM-140 DG Macro flash — Kenko tubes
Jon
Joined Jun 2004
Apr 23, 2008 09:19 |  #2
Does the dial on the grip work?
Jon
Cocker Spaniels
Molnies
Apr 23, 2008 09:21 |  #3
Thanks Jon!
I hadn't even thought about that. Yes, the dial on the grip worked, so at least I can operate the camera and we know it's a problem with the main dial not connecting (or something).
I guess I'll call Canon and ask what the charge for fixing this problem...
Once again, thanks!
Jon
Joined Jun 2004
Apr 23, 2008 09:24 |  #4
Try a shot of air in case there's some junk interfering with the switch? I wouldn't try any kind of solvent, though.
Jon
Cocker Spaniels
Molnies
Apr 23, 2008 09:31 |  #5
Jon, I can't thank you enough. A few squeezes from my air blower actually did the trick, so now the dial operates just like it should. I would have never even though about that, so well... Thanks!
(This is one of the many reasons I love this forum so much!)
sjlund
Aug 04, 2008 16:01 |  #6
Reviving a dead thread... this happened to me also. The dial on my XTi stopped working. After spinning the dial on my grip, the dial on the body worked fine. Something must have gotten crossed up in the programming and using the grip dial cleared it out.
SOT
I make up stuff about Cameras
Aug 04, 2008 16:06 |  #7
I have seen that happen a couple times, it was actually the little "on/off" switch...it was half turned....and would allow the grip to work but not the main dial.
http://img81.imageshac​k.us/img81/8646/captur​e1o.jpg (external link)
sjlund
Aug 04, 2008 16:11 |  #8
It's entirely possible that was my issue... I have the Opteka grip and the on/off switch has always seemed a little loose.
christineeo
1 post
Joined Nov 2012
Dec 01, 2012 00:08 |  #9
I found this forum after tons of searching and YOU, Jon, have the answer to my problem! THANK YOU! I'd offer to name my firstborn after you (so great is my relief) but he's 16 and probably won't react well to a name change at this point. Nonetheless, I'm so glad you responded to the original post here.
And in my head, I will refer to my son as Parker(Jon) from this point on.
rrblint
Gallery: 84 photos
Joined May 2012
Dec 01, 2012 00:29 |  #10
christineeo wrote in post #15311151 (external link)
Jon's pretty amazing that way... glad that you got it fixed.:)
Mark
stuartphoto
1 post
Joined May 2017
May 10, 2017 21:52 |  #11
I know this is years later, but I felt it necessary to share my fix to this problem. I had tried air burst, etc with no luck. To be clear, the dial that is used with the right index finger to change shutter stopped responding. My fix was:
In M mode, hit the trash can button to enter magic lantern. Switched the option for "Expo/ Lock" from "OFF" to "AV/ISO", and it worked. Then I could switch it back to "OFF" and the wheel is responsive again.
11,799 views & 0 likes for this thread, 7 members have posted to it and it is followed by 2 members.
652 guests, 124 members online
