Thread started 23 Apr 2008 (Wednesday) 08:57
Is there a difference in IQ based on Shutter Speed?
johndevane
Apr 23, 2008 08:57 |  #1
Hey guys,
I've got a technical question about digital camera processors... Does the camera's digital imager perform better at slower or faster shutter speeds?
In other words, if I don't need to worry about motion blur, or DOF or noise issues, should I try to get a slower shutter speed to help the camera do it's work?
In this picture I was at 1/60, f14, ISO 100. Would it be "easier" for my camera to capture the image at a faster SS and f5? Or maybe a slower SS and f20? Therefore increasing the image quality?
I've heard something about keeping the ISO and the SS the same makes a good image, but I haven't found info on this subject.
Thanks in advance,
John.
MKIII, 40D, XTI, 70-200 f/4L, 100-400L, 17-85 IS, 85 1.8, 100 2.8 Macro, 580 EX II, 550 EX, Bee's, PW's
Jim ­ G
I feel thoroughly satisfied
Joined Jun 2005
Apr 23, 2008 08:58 |  #2
Makes no difference... at least, not purely based on shutter speed. I don't believe there's any reason why keeping the shutter speed and ISO figures the same would possibly result in a superior image. I sure don't use ISO 1600 with 1/1600 shutter speed ;)
Image quality will be highest at ISO 100 and progressively decline as you head up towards 1600 and 3200... if you want the best possible IQ for a given situation use the lowest ISO you can get away with. Lower ISO will make for a longer shutter speed - it won't be the SS that'll change the IQ, it's the ISO.
Gear Listhttp://www.codastudios​.com.au (external link) Reviews & Hotlinks: Domke F-3x - Pelican 1510/1514 (external link) & 1610/1614 (external link) - DIY Variable Length OC-E3 - Crumpler 6 Million Dollar Home (external link) - FA-100 (external link)
Stocky
Apr 23, 2008 09:15 |  #3
iso 100 and an exposure of less than 1-5 seconds should make noise a non-issue, so the only reason I can think that shutter speed would make a difference, if you don't care about aperture, is camera shake. A solid tripod would fix this. I am not sure what shutter speeds are most sensitive to shutter slap though.
Always happy to hear some critique
gear list
Glenn ­ NK
Apr 23, 2008 09:23 |  #4
If you've noticed a difference in IQ with shutter speed, then you are likely experiencing movement of the camera during exposure. Obviously handheld exposures are most likely to reflect movement, but tripod exposures will record movement also if the vibrations caused by the mirror "slapping up" are not damped out when the shutter opens.
This is why mirror lockup (MLU) is often recommended - allow a couple of seconds after the mirror goes up for vibrations to die down, then release the shutter. It doesn't matter what the shutter speed is when mirror slap is the problem as it goes up at the same speed no matter what the shutter speed. Vibration caused by the shutter opening is also a possibility, but it's generally considered to be very small. The closing of the shutter also imparts vibrations, but since it's closed, it has no effect on the image.
A cheap tripod can also contribute to movement, particularly if there is any wind.
The first article is long, but worthwhile reading:
http://markins.com/cha​rlie/report4e6.pdf (external link)
http://www.luminous-landscape.com …-series/mirror-lock.shtml (external link)
http://www.luminous-landscape.com/essays/t​ripods_&_heads.shtml (external link)
As long as your long images aren't being over-exposed, there should be no discernible differences with various shutter times.
When did voluptuous become voluminous?
gjl711
Apr 23, 2008 09:24 |  #5
Stocky wrote in post #5387535 (external link)
..the only reason I can think that shutter speed would make a difference, if you don't care about aperture, is camera shake. A solid tripod would fix this. I am not sure what shutter speeds are most sensitive to shutter slap though.
I would venture a guess that whatever shutter vibration you do get from all the mechanical devices flying around would most be noticeable at less than 1/60 but more than 1/2 second.
Not sure why, but call me JJ.
::Flickr:: (external link)
::Gear::
johndevane
Apr 23, 2008 09:37 |  #6
Thanks for the quick resonses,
I'm not having a problem or noticing differences in IQ with different shutter speeds, I was asking if I should try to use a slower or faster SS when conditions permit.
For instance, in sports we can't adjust much because we need a fairly fast SS to avoid motion blur. But in scenery we could adjust the SS quite a bit. If it would help make a better image, I'd like to know which way to adjust.
Is the camera straining at 1/4000 and having trouble imaging so fast? Or is the camera straining at 1/40 and having trouble imaging so slow? I just want to be nice to my camera and have it be nice to me in return! :)
gjl711
Apr 23, 2008 09:51 |  #7
johndevane wrote in post #5387637 (external link)
The speed of the shutter is totally independent on the electronics ability to read the sensor. The read does not happen while the shutter open, but after it closes. Think if the process this way.
  • Buffers cleared.
  • Shutter opens exposing sensor
  • Shutter closes, no more light hitting sensor
  • Electronics reads the individual pixels and assembles the pic.
All the processing happens after so the speed of the shutter is irrelevant to the ability of the camera to capture that data. The shutter itself also moves no faster the higher the shutter speed, it’s just that the gap between the blades becomes closer.
::Gear::
RTMiller
Joined Dec 2004
Apr 23, 2008 10:05 |  #8
gjl711 wrote in post #5387713 (external link)
Really? Interesting. I did not know that. I knew about the slit/gap size but I just assumed that the speed varied also. Very interesting.
Todd
www.PHOTODDGRAPHY.com (external link)
Equipment List
Everyone is beautiful if you squint.
Wilt
Apr 23, 2008 15:13 |  #9
Mirror-slap induced vibrations have been shown in testing to be most problematic at shutter speeds between about 1/8 and 2, as the vibrations occupy a larger fraction of the total exposure time when inside that range. That was done with 35mm film cameras a couple decades ago.
Glenn ­ NK
Apr 23, 2008 15:37 |  #10
I tend to use the fastest shutter speed that will still enable a reasonable ISO and an aperture for adequate DOF.
Tixeon
Joined Oct 2004
Apr 23, 2008 16:35 |  #11
johndevane wrote in post #5387464 (external link)
Hey guys,
All good answers above, but, I'll touch on the subject of keeping the ISO & the SS the same. This goes back to the Sunny 16 rule. Brief description: When setting exposure manually in bright sun conditions, set the f/stop to 16 & the shutter speed to that of the ISO for a good exposure.
Tim
______
Any cat owner will tell you -- no one really owns a cat...
DocFrankenstein
Joined Apr 2004
Apr 23, 2008 16:44 |  #12
It doesn't make a difference for shutter speeds of less than a second.
When you open your shutter for a really long time, like 30 seconds or a couple of minutes, you will get a bit more noise.
National Sarcasm Society. Like we need your support.
swampler
Apr 23, 2008 16:46 |  #13
Tixeon wrote in post #5390037 (external link)
You beat me to it. This is exactly right.
Steve
Glenn ­ NK
Apr 23, 2008 23:00 |  #14
DocFrankenstein wrote in post #5390109 (external link)
Yessiree. Very good point.
So, in the range of 1/8000 second to around 1/2 second or so, the answer to the OP's question would there is no discernible difference in IQ provided there is no movement of the projected image on the sensor (whatever the cause of the movement).
Far more important is exposing as far as possible to the right of the histogram without blowing out the highlights. And let the blacks fall where they may - you can't do anything about the blacks anyway without using a technique like HDR.
johndevane
Apr 23, 2008 23:04 |  #15
Ahhh... the sunny 16 !
That's where I heard it. Thanks again to all.
John.
1,408 views & 0 likes for this thread, 10 members have posted to it.
2664 guests, 167 members online
