Thread started 26 Nov 2004 (Friday) 18:15
How's this for a cheap flash?
Ogrt48
Joined May 2004
Nov 26, 2004 18:15 |  #1
Well I just ordered this since it really was the most I could spend on a flash right now. I don't do anything pro, I mainly just take indoor pictures of my doggies and other random things.
http://www.amazon.com …%5Fencoding=UTF​8&v=glance (external link)
Gallery (external link)
robertwgross
Joined Nov 2002
Nov 27, 2004 00:02 |  #2
What camera do you intend to use it on?
---Bob Gross---
Ogrt48
Joined May 2004
Nov 27, 2004 01:15 |  #3
Just for the Rebel indoors with my pets, nothing serious or anything I'll be selling.
RichardtheSane
Joined Jun 2003
Nov 27, 2004 01:28 |  #4
This flash may not fire on the Rebel hotshoe without further additions...
Not sure of exactly what but it is only a TTL compatible flash and the new bodies require ETTL
If in doubt, I shut up...
Gear: 40D, 12-24mm AT-X Pro, 17-85mm, Sigma 150mm Macro Sigma 100-300 F4, 550EX, other stuff that probably helps me on my way.
Ogrt48
Joined May 2004
Nov 27, 2004 01:41 |  #5
Do they actually require ETTL?
Anyways from a search on dpreview ( yes ewww, I know) it seems to work on this camera and many more, it's also under the 6 volts.
Ogrt48
Joined May 2004
Nov 27, 2004 01:47 |  #6
Ah, I just got the PDF of the manual from amazon's site, it says it's compatible with all EOS cameras.
chops
Joined Oct 2004
Nov 27, 2004 05:58 |  #7
It will work with film, but not digital. Just like Canon's EZ series flashes, they will work on film bodies, but not digital.... At least not correctly. That's why they came out with the EX series.
Canon 10D w/ BG-ED3 Grip
Canon EF 50mm F1.8 Mk II
Canon EF 28-105 F3.5-4.5 Mk II
SanDisk 2GB Ultra II & Extreme III
http://charlest.zenfol​io.com/ (external link)
leonid
Joined Dec 2003
Nov 27, 2004 07:26 |  #8
I have a simple Vivitar 2800. It has only one contact on the hot shoe. And it works with my Digital Rebel just fine. Of course by "works" I mean it fires the flash, no other goodies like TTL or E-TTL.
Honestly, I am glad it does not have any TTL. I am very frustrated with E-TTL of build-in flash, which performance is unpredictable and totally depends on the colour of the subject, which is right in the centre of the frame. If your pet is white or black, TTL is not for you. After all, you can always adjust your exposure with aperture settings as long as you know, that TTL will not play tricks on you, by changing the exposure when you don't expect it.
The only concern is, would this flash fire focus assist beam? Mine does not.
Jim_T
Joined Nov 2003
Nov 27, 2004 20:29 |  #9
Yes.. For fully automatic operation, Canon DSLRs require E-TTL to obtain exposure info by using a pre-flash.
The 728AF appears to support only TTL. It will work in full automatic mode with Canon SLRs which can use TTL flashes like the Canon EZ series, but not DSLRs which require EX series flashes.
It does have a thyristor, so you may be able to get good results using the flash manually.
http://www.vivitar.com​/Products/PDFs/Flash/7​28AF.pdf (external link)
1,917 views & 0 likes for this thread, 6 members have posted to it.
1760 guests, 133 members online
