Thread started 26 Nov 2004 (Friday) 19:48
50mm focal length
mikesd
Joined Mar 2004
Nov 26, 2004 19:48 |  #1
Due to the fact that I have a very small studio [12x12ft] I was wandering if the Canon 50mm f/1.8 and the f1.4 are the same as the 50mm setting on the 18-55mm kit lens. Thanks in advance for the info.
50D, 10D, XT, S3 IS, Tamron 17-50, Tamron 28-75, Tamron 18-200, 18-55, 430EX II
Adam ­ Hicks
Joined Apr 2004
Nov 26, 2004 19:53 |  #2
They're both 50mm. You could also get 50mm by using a 1.4x extender on a 17-40L.
mikesd
Joined Mar 2004
Nov 26, 2004 19:54 |  #3
Thanks Adam.
tim
Light Bringer
Nov 26, 2004 20:23 |  #4
The focal length is the same, but obvisouly the aperature isn't. That's probably stating the obvious but just in case...
slin100
Joined Sep 2003
Nov 28, 2004 07:44 |  #5
The indicated focal length is usually only correct when the lens is focused to infinity. The field of view of a lens will usually change slightly when a lens is focused to less than infinity. The difference can sometimes be significant at close distances.
Steven
7D, 10D, 17-40/4L, 50/1.8 Mk I, 85/1.8, Tamron 28-75/2.8, 28-135/3.5-5.6 IS, 80-200/2.8L, 550EX, Pocket Wizard
robertwgross
Joined Nov 2002
Nov 28, 2004 09:43 |  #6
Do you know why this may be the case?
We could probably answer this easily if we worked in the Canon design lab.
---Bob Gross---
psychedelic_never
Joined Aug 2004
Nov 28, 2004 11:10 |  #7
I think this is only true for lenses that use internal focusing mechanisms.
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Nov 28, 2004 11:20 |  #8
Not really. The Canon T-cons won't even fit on this lens....
....and even of you found a T-con that would physically fit on the 17-40mm.. it would not function correctly.
T-cons are designed to work with telephoto lenses with narrow feilds of view. A T-con on a lens this wide would cause pretty drastic vignette.
CDS' HOT LINKS
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Nov 28, 2004 11:23 |  #9
mikesd wrote:
... I was wandering if the Canon 50mm f/1.8 and the f1.4 are the same as the 50mm setting on the 18-55mm kit lens. Thanks in advance for the info.
I'm not clear what you mean by "The Same"
The focal lenght is the same,. but the image quality and f/stop are dramtically different.
Both of the primes will offer superior image quality, sharpess etc. and the ability to offer functionality in much lower lighting than the zoom.
CDS' HOT LINKS
slin100
Joined Sep 2003
Nov 28, 2004 13:01 |  #10
I'm not a lens designer, but if you start with the basic lens equation 1/f = 1/i + 1/o and derive image magnification i/o, you can predict that magnification will increase (and FOV will decrease) as the subject distance decreases. The lens equation only goes so far, because none of our lenses are simple, ideal lenses. There's nothing that requires the lens designer to maintain a constant focal length as the various lens groups are moved, even on a prime lens!
I just checked all of my lenses and the field of view in all but one lens varies as I move the focus ring from infinity to a closer distance:
  • 80-200/2.8L: FOV decreases
  • 50/1.8 Mk I: FOV decreases
  • 28-135/3.5-5.6 IS: FOV increases
  • Tamron 28-75/2.8: FOV increases
  • 17-40/4L: FOV constant
I was a bit surprised about the 17-40L. It is, however, a parfocal zoom, which means it maintains constant focus as focal length is varied. Perhaps the designers also engineered it to maintain a constant focal length as focus is varied. The 80-200L is supposed to be parfocal, too, but it doesn't maintain a constant FOV. Based on my observations, it would seem that there are a number of variables when it comes to lens design.
Steven
FlyingPete
I am immune
Joined Oct 2003
Nov 28, 2004 14:15 |  #11
I have seen this when using my 75-300 at around 300mm with close up filters on it, it is quite noticeable!
Peter Lowden.
EOS R6 and assorted glass
Jon
Joined Jun 2004
Nov 29, 2004 13:34 |  #12
It's important to note that what you're seeing is just the captured area of the image. The lens' area of coverage hasn't changed, just the portion of theat circle you capture. One other thing you should consider in this experiment is what focal length you're working at. Wide angle lenses (including zooms) are retro-focus designs, so it doesn't (after the fact, never really considered it before) astound me that as you close-focus a WA zoom at its widest, it would effectively become somewhat "wider". You might see different results if you were to try the same lens at full telephoto position as conditions there are quite different. And since the design requirements for a parfocal lens are signficantly different than those for variable-focus zooms, I'd expect its' behaviour to more closely approach that of a prime or tele-zoom.
That's because using a close-up lens physically alters the focal length of the compound lens. That's how close-up lenses work. If you change the focal length of the lens, of course you'll change the field of view.
Jon
Cocker Spaniels
2,601 views & 0 likes for this thread, 9 members have posted to it.
50mm focal length
1772 guests, 133 members online
