Thread started 24 Apr 2008 (Thursday) 00:00
How do you get cotton water effect in daylight?
kekoa
Apr 24, 2008 00:00 |  #1
Hi all, how does one get that cotton looking waterfall look in broad daylight? I know how its done with lower light. I usually go to tv mode and slow the shutter speed down. But in daylight, I can't get that effect. I normally shoot in AV mode and if I slow the shutter down too much, the shot is way over exposed. Do i need to go to manual and play with settings? I'm just not familiar or experienced enough with M mode.
thanks
T.D.
Moderator
Gallery: 13 photos
Apr 24, 2008 00:03 |  #2
Use a Neutral Density Filter (or a few stacked). And Manual is the way to go, but Av can also work just fine.
(My Gallery) (external link)
horrgakx
Joined Jan 2005
Apr 24, 2008 02:17 as a reply to  @ T.D.'s post |  #3
Exactly right. And something I'm looking into at the moment.
I bought a graduated ND filter (in order to reduce the sky brightness), an ND8 and also an ND400. I can stack these with a circular polariser too in order to REALLY slow the shutter.
I went out about a week or so ago with the ND400 in bright sunlight but I didn't get the effect I was after. I wanted to get this cotton-water effect like I have done in the past at dusk - but I did get something from the day.
IMAGE: http://farm4.static.flickr.com/3158/2421864264_17d30b408d_m.jpg
The Flickr page for this photo is
http://www.flickr.com/​photos/horrgakx/242186​4264/ (external link)
http://dave-wilson-weddings.com (external link)
http://photographynort​hwest.com (external link)
Flickr gallery - http://flickr.com/horr​gakx/sets (external link)
kevin_c
Apr 24, 2008 02:25 |  #4
Lowest ISO you can go to (100 usually) - slowest shutter speed that the correct exposure will allow, around 1/4 or 1/8th sec usually works for me but it depends on the effect you are after (using 'M' doesn't help one bit, It's still got to be properly exposed!)
Neutral Density filter or filters (you can stack them).
A polarizer will also give you 1-2 stops
Shoot on an overcast day :-)
-- K e v i n --
Nikon D700, 17-35mm, 28-105mm, 70-200mmVR, 50mm f/1.4
Canon EOS 3, 24-105L, 135L
Stocky
Apr 24, 2008 05:32 |  #5
The same thing came up here: https://photography-on-the.net …/showthread.php​?p=5391794
a few hours before your post.
Always happy to hear some critique
gear list
kekoa
Apr 24, 2008 10:07 as a reply to  @ Stocky's post |  #6
Wow, the whole filters thing has me somewhat confused. From my understanding, certain filters will allow you to slow the shutter a lot more bye Letting less light into the camera? Do the ND filters come in packs so you can stack them? And how much does a quality set run?
tiktaalik
Joined Feb 2006
Apr 24, 2008 10:25 |  #7
You can get a variable neutral density filter (the Vari-ND) from Singh-Ray (external link) which varies from 2 stops to 8 stops. If you want more ND, you can then add their 5 stop "Mor-Slo". With this combination you can expose several minutes in bright daylight.
Be warned - Singh-Ray is very pricey but I find their filters worth it.
Julie
My galleries (external link)
https://photography-on-the.net …hp?p=1330884&po​stcount=56
horrgakx
Joined Jan 2005
Apr 24, 2008 10:51 as a reply to  @ tiktaalik's post |  #8
Exactly. Its like one of those filters you use on telescopes to look directly at the sun. Exactly the same principal - its like a pair of sunglasses for your lens :)
Yes you can stack them - they have threads on both sides so you could stack 50 of them if you wanted.
Prices - in the UK you can walk into a high street store and buy up to an ND8 for under £30.
Darker ones are generally more speciallist and I got my ND400 from China through eBay for about £35 (same for the graduated ND filter).
kekoa
Apr 24, 2008 12:20 |  #9
tiktaalik wrote in post #5394664 (external link)
OMG. that is an awesome link.
i can't beleive those filters cost so much. :(. I guess i'm stuck to wait until dawn to get the affect i want for a while. :cry:
Canonswhitelensesrule
Apr 25, 2008 16:17 |  #10
As others have mentioned, low ISO, slow shutter speed, possible use of polarizing and/or ND filters etc.
I took the photograph below during a bright, sunny late July morning with my Canon EOS A2 film camera on Velvia 50 slide film. I used a 3 stop ND filter, and of course my camera was tripod mounted. I used a shutter speed of I believe 2 to 4 seconds.
HTTP response: NOT FOUND | MIME changed to 'image/gif' | Redirected to error image by TINYPIC
Here is the same waterfalls/river taken a few seconds later using a fast (1/2,000th) shutter speed.:
IMAGE: http://i30.tinypic.com/23j4ufk.jpg
Photographers do it in 1/1,000th of a second...but the memory lasts forever! ;)
"It's only cheating if you get caught!" - Al Bundy
People who THINK they know it all really annoy those of us who DO!
Sgt.
Gallery: 56 photos
Apr 26, 2008 01:35 as a reply to  @ Canonswhitelensesrule's post |  #11
Nobody mentioned to use your smallest aperture opening as well
Iain
7D MKII
Another minion in the Pondrader fan club
horrgakx
Joined Jan 2005
Apr 26, 2008 03:34 |  #12
Sgt. wrote in post #5406496 (external link)
True to a point. Diffraction is your enemy when using small apertures. Use an ND filter and you don't necessarily have to stop right down.
kevin_c
Apr 26, 2008 04:05 |  #13
No, but by the very nature of the problem - too much light, I think we are kinda' assuming that the OP can't go any smaller, and as horrgakx just pointed out ^^^^ , you don't always want to, or have to, use the min aperture - by using ND's you can open up a bit and use something around f/8 and still get a slow enough shutter speed.
-- K e v i n --
Angry ­ Dad
Apr 26, 2008 12:30 |  #14
Canonswhitelensesrule wrote in post #5403898 (external link)
Is it me or do these photos have a heavy blue cast to them? My monitor is not calibrated BTW.
www.tembophotography.c​omCanon 5DmkII, Canon 70-200mm 2.8L II Canon 35mm 1.4L Canon 24-105L Sigma 50mm 1.4 EX and a bunch of other crap. (external link)
Apr 26, 2008 16:50 |  #15
Angry Dad wrote in post #5408314 (external link)
The "cotton candy" effect photo does have a blue cast to it, which I actually like. It makes the water appear more "soft" and "cool". At least IMHO. ;)
The second one doesn't have that much of a blue cast.
4,652 views & 0 likes for this thread, 14 members have posted to it.
2814 guests, 162 members online
