Thread started 24 Apr 2008 (Thursday) 07:17
Seem to lose sharpness of an image when it is reduced -why?
cookey
Gallery: 29 photos
Apr 24, 2008 07:17 |  #1
Hello,
I took a few images at a photo shoot & when the images are about 3200 x 2000 they look nice & sharp.
I was wondering why when reduced to 800 x 600 for putting on a website they seem to lose a degree of sharpness.
I converted the images from RAW to jpeg,should I be saving the images in a different format?
Advice appreciated please.
Canon 5DMKII & 30D
50mm 1.4 USM 24-70L 2.8 85mm 1.8 USM 70-200L 2.8IS
3x430EX 1x580EXII Cybersyncs
John_B
Gallery: 178 photos
Apr 24, 2008 07:23 |  #2
cookey,
If you start with 3200 pixels and reduce to 800 pixels where did the 2400 other pixels go? That maybe the reason why you usually have to apply USM or sharpening to a reduced sized file to get it to equal sharpness as the original.
click to see (external link)
cookey
Gallery: 29 photos
Apr 24, 2008 07:29 |  #3
I did the sharpening before I resized my picture,so it is best not to do any PP before resizing then & then do it after?
Canon 5DMKII & 30D
qtaran111
Apr 24, 2008 07:30 |  #4
This is a consequence of resizing from a larger image to a smaller one and happens with all image types and programs used to resize (to differing extents).
Think about it; the program you use to resize the image has to take the 6.4 million pixels in your original and represent this in 480k pixels. To do this the program uses all sorts of clever interpolation algorithms, along the way trying to maintain sharpness, contrast, avoid moiré patterns etc, etc.
The moral of the story is to apply a little sharpening after you have resized (generally USM or high pass is best). Most folks include the sharpening as part of their resize batch processing.
Camden Photographic (external link) | Smugmug (external link)[COLOR=black] | CompuTrekker AW Review (external link) | Gear
cookey
Gallery: 29 photos
Apr 24, 2008 07:49 |  #5
thanks very much for the tips
Canon 5DMKII & 30D
René ­ Damkot
Apr 24, 2008 08:07 |  #6
If you use PS, give Manyk SRS (external link) a try.
Why Color Management.
Color Problems? Click here.
MySpace (external link)
Twitter (external link)
JoYork
Apr 24, 2008 09:42 |  #7
Also, (assuming you're using Photoshop) when you resize the image make sure you choose Bicubic Sharpen instead of plain old Bicubic.
Jo
guitarman2977
Apr 24, 2008 09:55 |  #8
This might be a little off topic, but does anybody know if Lightroom applies sharpening automatically to files when exporting a RAW file to a small jpeg, say 800x600? I swear some of my pictures look sharper as a jpeg export than they did in the Develop mode in Lightroom.
** 365 Project ** (external link) | my photo blog (external link) | website (external link)
Canon 5D & 30D. 24-70 2.8L. 100mm f/2. 50 1.4. 50mm 1.8. 580 EX. 430 EX II.
tdodd
Apr 24, 2008 10:16 |  #9
guitarman2977 wrote in post #5394485 (external link)
I can't answer your question about LR sharpening on output, but I have noticed that images look sharper in LR when viewed at 1:2, 1:3, 1:4 sizes rather than Fit or Fill. Whenever I resize anything for the web I always try to resize to 1:integer rather than some random reduction ratio just to fit an exact pixel size.
e.g. files from my 40D are 3888 * xxxx pixels. I always output to 972 * xxx (1:4 ratio) or 778 * xxx (1:5 ratio). If I aim for 1024 *xxx or 800 * xxx, for example, the final images do not look as good to me. The same thing goes for files viewed within or output from DPP too.
guitarman2977
Apr 24, 2008 10:23 |  #10
tdodd wrote in post #5394608 (external link)
That's a great idea. Thanks! I'll have to try exporting to pixel dimensions that are a factor of the original. Does anyone else on here resize this way?
bsmotril
Gallery: 11 photos
Joined Feb 2006
Apr 24, 2008 10:41 |  #11
What I usually do is apply USM to the large image with a radius of 1 pixel, and threshold somewhere between 1-5.
Then resize, and apply smart sharpen to the resized picture around 35% and Gaussian blur removal mode. When I resize, I try to resize to an even multiple of the original size. IE, if your image is 4000 pixel, resize it to either 2000, 1000, 400, etc pixels. When you view the resized image, make sure you select the "View Actual Size" option as the interpolation LCD displays do on off sized images will often times make it look far worse than the actual image.
Galleries: http://www.flickr.com/​photos/smopho/ (external link) --- http://billsmotrilla.z​enfolio.com/ (external link)
guitarman2977
Apr 24, 2008 11:18 |  #12
bsmotril wrote in post #5394749 (external link)
So if I crop a RAW image in post processing, do I need to figure out the new pixel width and export to a factor of that number, or does it work to still base it off the original image size?
René ­ Damkot
Apr 24, 2008 11:27 |  #13
AFAIK LR 1.4 doesn't offer output sharpening LR 2.0 beta does.
tdodd
Apr 24, 2008 11:49 |  #14
guitarman2977 wrote in post #5394970 (external link)
You'd have to calculate the output dimensions based on the cropped image, not the original. Once you've cropped to a new size, it doesn't matter at all what size the file started out at. You've effectively thrown some pixels away. Pretend they were never there. The idea is that....
for a 1:2 ratio you are squeezing exactly 2X2 input pixels into one output pixel;
for a 1:3 ratio you are squeezing exactly 3X3 input pixels into one output pixel;
for a 1:4 ratio you are squeezing exactly 4X4 input pixels into one output pixel
This means that the software is not having to guess at what, for argument's sake, squashing 2.36X2.36 or 3.437X3.437 pixels into one should look like. How can the software figure out what those odd bits of pixels should look like - it has to guess. When you squash by integer factors it keeps the maths clean and simple and the software can do a cleaner job of calculating what the new, shrunken pixels should look like.
Well that's my theory :)
guitarman2977
Apr 24, 2008 12:00 |  #15
Great information, tdodd. That makes perfect sense. Thanks!
1,655 views & 0 likes for this thread, 8 members have posted to it.
2664 guests, 167 members online
