For P&S cameras, what is the main difference between changing ISO and changing exposure? I notice that both seem to serve to enhance the brightness of a otherwise too dark image and both need a slower shutter speed. So when should I use which?
g3ck0 Member 223 posts Joined Apr 2008 Location: Bay Area, CA More info | Apr 25, 2008 00:52 | #1 For P&S cameras, what is the main difference between changing ISO and changing exposure? I notice that both seem to serve to enhance the brightness of a otherwise too dark image and both need a slower shutter speed. So when should I use which? Canon 7D | 50 1.4 | 17-55 IS | 10-22 | 18-55 IS | 70-200 F4 IS | 430EX
dicktay Senior Member 603 posts Joined Jan 2007 Location: Sydney, Australia More info | Apr 25, 2008 01:31 | #2 Changing the ISO value changes the exposure . Increasing the ISO helps you to shoot in dimmer light.
Jon Cream of the Crop 69,628 posts Likes: 227 Joined Jun 2004 Location: Bethesda, MD USA More info | Apr 25, 2008 09:11 | #3 Ideally, when you change the ISO setting on the camera (in any of the Auto modes), it'll meter just the same way at the new ISO setting. The new ISO setting makes the sensor more (or less) sensitive to the existing amount of light, so the exposure will need less (or more) light to get a "correct" exposure (the more sensitive, or higher, the ISO, the less light it needs to "see" the image). You'll see the shutter speed and aperture change (if your camera gives you this information), but the overall brightness of the picture won't change. Jon
| Latest registered member was a spammer, and banned as such! 1574 guests, 135 members online Simultaneous users record so far is 15,144, that happened on Nov 22, 2018 | |||
