Thread started 25 Apr 2008 (Friday) 15:27
how can i use 2x flash with 20D
Canon400
Apr 25, 2008 15:27 |  #1
hi
i just wantt o know if i can use 2 flash units with my 20D.
i have a 380Ex speed light with a hotshoe cable i want to hook up another flash to the camera can this be done ? and how
i also have a pc cord connection socket on the side of the camera can i plug another flash there at the same time as hotshoe?
many thanks for the help
CANON 400D , CANON 20D EFS 17-85 IS EF 70 210 EF 50MM F1.8 380EX 17-135IS
nadtz
Apr 25, 2008 16:02 |  #2
1 on hotshoe, 1 via pc sync will work.
FlashZebra
This space available
Apr 25, 2008 16:32 |  #3
Canon400 wrote in post #5403574 (external link)
hi
You can use the hotshoe and the PC connector both at the same time. I think this is stated explicitly in the owners manual.
Enjoy! Lon
SkipD
Joined Dec 2002
Apr 25, 2008 16:36 |  #4
Of course, if you use the PC terminal to trigger a flash, you should set ALL of your flash equipment and your camera's exposure control to manual mode. ETTL and manually triggered flash equipment don't add up to automated ability to control exposures.
Skip Douglas
Canon400
Apr 25, 2008 17:48 |  #5
what flash units will take pc connections? i know the 380ex only takes shoe cable
FlashZebra
Apr 25, 2008 21:07 |  #6
Canon400 wrote in post #5404310 (external link)
There are likely hundreds of different hotshoe based flash units that will accept some sort of sync cord directly with a plug in port. A subset of those will accept the PC sync connector.
And, there are hundreds of hotshoe based flash units that have no built in sync port, so the hotshoe is the only way to access sync on those.
Enjoy! Lon
Tomi ­ Hawk
Gallery: 21 photos
May 03, 2008 21:38 as a reply to  @ FlashZebra's post |  #7
What about the use of a *slave* on the other flash?
1,316 views & 0 likes for this thread, 5 members have posted to it.
1543 guests, 188 members online
