GrendelZ wrote in post #5407481
Well I have been shooting with the 70-200 but f4 just doesn't give the kind of oof background I want. The primes just give a buttery smooth look that you cant get at F4.
Well, you can, but you have to choose yoru background a bit more carefully. The advantage of the 24, 35, 50, 85 and 135 Ls is that they are especially corrected for good bokeh, which makes it a lot easier, as do the large maximum apertures they have. Of course, the advantage of having good bokeh does seem to come with some logitudinal chromatic aberrations at large openings at strong contrast edges.
I have a 50 1.8 and it does a good job but not like the L's and I would like to have full time manual focus override.
Mainly I am asking if the 85 justifies the $600 premium it commands over the 50.
Well, I think that is relative. The 85L is still the bokeh king, but not necessarily appropriate for all subjects, distances or situations. When you need the 85L it is worth it, and so is the 50L.
I have considered the 135 too but it seems to be a little long. I set my 70-200 to 135 and did a little shooting and it seemed to be long for most instances.
It often is a little long, but while I waited for the 50L to be sorted out, I got a 50 F/1.8 Mk I, and I had the 85 F/1.8 and 28 F/1.8, and I found I tried to use the 85L all the time, it is that good. The 50L is about as good, but the bokeh and feel is different, essentially because of the larger FoV it gives you, with the different depth/DoF representation that goes with it.
I do find that lately I almost exclusively use the 24L, 50L and 85L, with a little bit of 10-22, and 10-17 fisheye, and occasionally the 70-200. All this generally for indoor without flash shots, although I went out yesterday to do some landscape work with the set.
BTW WIMG, your gear is worth more than my car
Yes, tell me about it
, same here
. I was lucky to sell my analog equipment about 7 years ago, when it was still worth something (had 4 - Pentax - bodies and 13 lenses at the time), continued saving until I got my first digital P&S (G5) about 2 1/2 years ago, and a 350D half a year later. I had started reading POTN already by that time
. I got a little windfall last year as well, and despite that I am utterly broke now
, but very happy with my equipment, I can assure you ...
Kind regards, Wim
