Thread started 27 Nov 2004 (Saturday) 21:36
Tamron Extenders
swatcop169
Nov 27, 2004 21:36 |  #1
I was looking around on B&H and found the Tamron 1.4x extender. Anyone have this? Its about $80 compaired to Canon's $200
Just wondering about image quailty, etc with it.
| Canon R5 | RF 24-70L 2.8 | RF 100-500L 4.5 |
robertwgross
Joined Nov 2002
Nov 27, 2004 22:09 |  #2
I have one Tamron MC4, and I also have a Canon.
Which one you want to use depends on what lens it will be used with.
---Bob Gross---
swatcop169
Nov 27, 2004 22:20 |  #3
Mostly my 70-200 f/4L
robertwgross
Joined Nov 2002
Nov 27, 2004 22:59 |  #4
I think you'll find there is a lot of difference in teleconverters beyond the price tag.
---Bob Gross---
swatcop169
Nov 27, 2004 22:59 |  #5
---Bob Gross---
Hense the reason I asked.
robertwgross
Joined Nov 2002
Nov 27, 2004 23:10 |  #6
We assume that you read the sticky thread about teleconverters.
All x1.4 teleconverters will decrease your light by one stop. For some camera bodies and some lenses, this will mean the difference between autofocus and no autofocus.
Basically, for an L lens, I stick to the Canon type. For a consumer-type lens, I stick to the Tamron type. I won't or can't put the Canon on a consumer-type lens.
If you start with a really sharp lens and add a really good teleconverter, then you will get a really good x1.4 result. Any other combination, and it won't be quite that perfect.
I stack them. One 100-400mm L lens, one Canon x1.4, one Tamrom x1.4, then the camera.
---Bob Gross---
kdw3535
1 post
Joined Aug 2004
Nov 27, 2004 23:42 |  #7
blackviolet
Joined Apr 2004
Location: sydney, au (now in singapore for a few years)
Nov 28, 2004 02:07 |  #8
there are 2 tamron 1.4 extenders. the cheap one (black one) has 4 elements and is pretty cheap in price. you usually find this one in the cheap section with cheap lenses (28-200's 90-300's, etc.). the quality on this is noticably crudy - soft, washed out, and a bit of edge distortion.
the sp model (the white one) is quite good, imho... it has 5 elements and doesn't really add any noticable distortion or softness. i've had both the sp and the canon and found it hard pressed to tell the difference between them. it's about US$170 vs. $270 for the canon. also, it will fit lenses without recessed rear elements and you can use it without 'taping' pins on slow lenses.
the sp 2x extender, on the other hand was not very good in my tests
oblio
1dmkiii - 5dmkii -Leica M8/M6 - Mamiya 645AFDiii/zd
ModelMayhem (external link) | my (external link)flick (external link)r gallery (external link)
samdring
Joined Aug 2003
Nov 28, 2004 04:59 |  #9
Very useful info - not sure but we don't seem to have a sticky on Tamron converters
Does that mean that the SP will fit any Canon/Tamron lens regardless of design (rear elements) or lens speed?
Have a Care
Sam
robertwgross
Joined Nov 2002
Nov 28, 2004 09:41 |  #10
There are basically two categories of teleconverters. One kind, I'll call it the Canon kind, will accept the back end of L lenses. The other kind, I'll call it the consumer kind, will accept anything in an EF lens.
It's kind of interesting, though. These seem to have similar function, but when you put them side-by-side, the difference becomes visibly more apparent. Then when used, the difference in the resultant image becomes more apparent.
---Bob Gross---
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Nov 28, 2004 10:51 |  #11
If anyone has any personal expeirnce and or a reference... a confirmed reference,. I could add Tamron info to the Sticky. As it is,. I have never touched one of these T-cons.
The info in the sticky is based on a combination of first hand expeirience,. manufacturer data, and input from the members of this forum. (thanks to all who keep adding to this endeavor! :) )
Part of the reason that the Sigma line is included is this forum up untill just recently, has been decidedly Canon and Sigma biased. Most users contributing have only had expeirience with these lenses.
Sigma T-cons are also virtually interchangeble with Canon T-cons as far as compatibility. And of course,. Sigma remeians to this day the only "Non-OEM" Mnaufacturere of Super Telephoto lenses.
Anyway.. I digress...
It would be great if we could get the Tamron info together and add it to the sticky. The trouble is.. I doubt it will be easy to find first hand info on compatibility with a $5,000.00 lens and a $75.00 T-con.... ?!
CDS' HOT LINKS
CyberDyneSystems
Admin (type T-2000)
Gallery: 193 photos
Joined Apr 2003
Nov 28, 2004 10:55 |  #12
For that excellent lens,. I would only put a Canon or Sigma 1.4X on it.. just my own humble opinion. The optical quality of the lens in question is superb,. and the Canon will maintian this excellent quality,.. with the Sigma also coming very close.
CDS' HOT LINKS
swatcop169
Nov 28, 2004 11:32 |  #13
Thanks, I'll check the sigma's out right now.
blackviolet
Joined Apr 2004
Nov 28, 2004 14:31 |  #14
CDS- i myself am very canon and sigma biased, but i am speaking from experience regarding the tamron 1.4x sp extender/teleconverter​. i definitely wouldn't lump it into Bob's 'consumer' pile.
i'll take some pix later when time and light permit...
oblio
robertwgross
Joined Nov 2002
Nov 28, 2004 18:49 |  #15
blackviolet wrote:
... but i am speaking from experience regarding the tamron 1.4x sp extender/teleconverter​. i definitely wouldn't lump it into Bob's 'consumer' pile.
I don't think that product has been mentioned here. Only MC4.
---Bob Gross---
3,978 views & 0 likes for this thread, 7 members have posted to it.
Tamron Extenders
1772 guests, 133 members online
