Thread started 26 Apr 2008 (Saturday) 01:15
Old Shed Under Tree
ImageMogul
Apr 26, 2008 01:15 |  #1
I'd appreciate some critique on this one guys (the whole process - composition through post). What would you have done - what would you do?
IMAGE: http://ImageMogul.smugmug.com/photos/285148104_6sYDf-L.jpg
Thanks much.
Mark
Composition can’t be reduced to a set of rules ... Dissonance has its place in photography as well as music. If we confined ourselves to major and minor scales, the blues wouldn’t exist. Rules are tools, not laws.” ~ James Martin
http://www.imagemogul.​smugmug.com/ (external link)
Bill ­ Boehme
Enjoy being spanked
Gallery: 39 photos
Apr 26, 2008 05:10 |  #2
I like it -- I think that it tells a great story. Even though there is a lot of grass, brush, and trees that has the potential to clutter the image, I think that the main elements in the scene are strong enough to not be overwhelmed and everything seems to exist together well. The one area that I think could be improved is to not use global sharpening. I think that the buildings and abandoned vehicle would benefit the most from sharpening -- and you have applied what looks like the right amount. However, strong sharpening of the grass, trees, and brush tends to raise the overall "busy" factor. I think that I would tone down the sharpening in those areas.
Atmospheric haze in images? Click for Tutorial to Reduce Atmospheric Haze with Photoshop.
Gear List .... Gallery: Woodturner Bill (external link)
Donate to Support POTN Operating Costs
tonydee
Apr 26, 2008 09:59 |  #3
Hi Mark. It's really very good, and the lighting and vividness of colour and tonal contrast in the grass and trees is superb. It's got a bit of that light-shining-through-greenery magic that's so hard to capture. My only nitpicks are that having the rear end of a ute like that inevitably draws the eye out of the picture, the sky behind looks blown and might have been usefully replaced with a light blue via a little PP trickery, and the tree trunk is a very strong element to put so centrally. I can't say without being there, but for those reasons I'd have hoped to find an even better angle walking around the scene. Cheers, Tony
5D and too much glass. Mamiya 645E.
http://www.picasaweb.c​om/anthonypon (external link) recent work
Flo
Gimmie Some Lovin
Apr 26, 2008 10:44 as a reply to  @ tonydee's post |  #4
To me I see two seperate photos here.the old rusty vehicle and the grasses.and then the sheds etc?
ImageMogul
Apr 26, 2008 13:16 |  #5
Thank you all for the helpful comments. Again, much appreciated.
bill boehme wrote in post #5406950 (external link)
...The one area that I think could be improved is to not use global sharpening. I think that the buildings and abandoned vehicle would benefit the most from sharpening -- ...
A great observation. Got to be honest Bill, I'm a novice when it comes to PP. I just purchased Elements 6 today (not used on this image) and I didn't even know that you could sharpen selectively. That is a great tool I will learn to make good use of.
tonydee wrote in post #5407721 (external link)
...My only nitpicks are that having the rear end of a ute like that inevitably draws the eye out of the picture, the sky behind looks blown and might have been usefully replaced with a light blue via a little PP trickery, and the tree trunk is a very strong element to put so centrally...
Can I selectively de-saturate the "ute" (actually a truck bed made into a trailer) & if so, would this help balance things more? To me it seems to distract because it is too saturated and vibrant vs. the more muted shed behind. PP trickery - yes, I must learn this new magic... I realize the rule of thirds was almost but not quite accomplished here. I was on my way home from a neighboring city and saw this little shed - I pulled into the lot, rolled down the window and shot several different orientations (I only had my P&S A540 at the time - the xti was at home). There were distracting elements to the left and right of the frame that I tried to frame out. I think I'll attempt a reshoot with DSLR and a wider lens (OK my only lens) which might let me get close enough to frame the "ute" out and see how that works. Thanks for the comments, tonydee.
Flo wrote in post #5407932 (external link)
I wish it were an old rusty vehicle instead of a trailer, Flo. That could make a neat shoot in the tall grass. I'm a "car guy" at heart. I'll see if I can revisit the site with new eyes soon - I was somewhat hurried on this trip and was lucky to have a camera of any sort in the car.
Thanks again all. Any further comments are welcomed.
Mark
midnitejam
Apr 29, 2008 17:32 as a reply to  @ ImageMogul's post |  #6
What I like most about the shot is your excellent post processing. I think your saturation, lighting, and sharpening processes really made that image.
The only thing I would mention is the rear-end of the old truck. It’s too far into the foreground and too obvious to be an effective anchor to lead the eye to building. It is competing with the building for the center of attention. It would have also worked with each element being in it’s own photo by itself (one subject for one photo).
Midnitejam--The happiness in your life depends on the quality of your thoughts.
ImageMogul
Apr 30, 2008 00:32 |  #7
midnitejam wrote in post #5429476 (external link)
...post processing...really made that image.
I did the best I could with what I had, and what I had wasn't much. Regardless, thank you for the kind words, midnite.
... rear-end of the old truck .... competing with the building for the center of attention...
I do agree. I have plenty of opportunity to swing by and try some different angles/framing. I'll take those opportunities as soon as schedules allow.
Mark
jpon2
Apr 30, 2008 04:33 |  #8
Works for me.
http://jp.exposuremana​ger.com (external link)
Canon Rebel XT 350D | Canon EF 200mm f/2.8 L II USM | Canon EF 50mm f/1.4 | Canon EF 24mm f/2.8 | Canon EF-S 18-55 mm (kit lens) Alien Bees 800
midnitejam
Apr 30, 2008 06:39 as a reply to  @ jpon2's post |  #9
Mark, you can still make this shot better. You can yet add dynamic lighting.
Remember that lighter portions get first attention. Lights come forward and darks recede. Try a dodge/burn procedure by setting your brush opacity to 5-15 % and add light to the face of the shed. Don't overdo it-- just enought to build a slight lighting ratio.
Next shoot, if it's possible select a time of day when the shed will be side lit.
Good luck,
midnitejam
midnitejam
Apr 30, 2008 12:59 as a reply to  @ midnitejam's post |  #10
Hey Mark, Here's some food for thought--Hope you don't mind......
kqueenkitty
Apr 30, 2008 13:40 |  #11
I think this is a great picture.
Kelly
Canon 50d
Right ­ Cranium ­ Imaging
Apr 30, 2008 18:19 |  #12
Just for fun, I added a little saturation and boosted the contrast a little then added the texturize filter in PS and it looked pretty cool, but I could not get the file size small enough to post it without it looking terrible or tiny
(Insert Over Used Photography Quote Here)
Canon Equipment - Mac Computers
MattMoore
Apr 30, 2008 21:01 |  #13
image is too horizontally centered, tree is centered.
Good cropping by midnite
midnitejam
Apr 30, 2008 22:29 |  #14
Right Cranium Imaging wrote in post #5436717 (external link)
Hi Right Cranium Imaging,
I'm really curious about your edit. It sounds interresting. Could you send a link to....
idnitejam@aol.com (external link)
ThanX
nw85887, Thank you for the honorable mention.
Michael Jan
Apr 30, 2008 22:48 |  #15
Sure, I just deleted it when it was too big, but I will do it again and try and get that up shortly
2,312 views & 0 likes for this thread, 12 members have posted to it.
Old Shed Under Tree
2602 guests, 167 members online
