Thread started 27 Apr 2008 (Sunday) 17:12
silly question
Canon400
Apr 27, 2008 17:12 |  #1
hi
Q1. if i get 2 old flash units & buy these hotshoe to pc sync adapters will they work with my camera eos 20D & 400D.
Q2. i have a 380ex flash what is the cheapest way to add another flash does it have to be an EX series. at the moment i use the 380 EX with a canon hotshoe cable i need another flash so i can get good lighting for portraits, basically all i want to do is connect 2 or 3 flash units to my camera.
if you can point me in the right direction or give any links that would be appreciated.
many thanks
CANON 400D , CANON 20D EFS 17-85 IS EF 70 210 EF 50MM F1.8 380EX 17-135IS
DDCSD
GIVIN' GOOD KARMA
Apr 27, 2008 17:47 |  #2
I recommend having a read of www.strobist.com (external link) . It is all about cheap off camera flash use. Start in the lighting 101 section.
You questions are very subjective and it depends on what you mean by cheap and if you are looking to use the flashes manually......
Derek
Bucketman Karma Fund
https://photography-on-the.net …php?p=9903477#p​ost9903477
POTN FF L2 MadTown Birds
Full Gear List & Feedback
PhotosGuy
Cream of the Crop, R.I.P.
Joined Feb 2004
Apr 28, 2008 10:32 |  #3
Q1: They should work. I'm not sure what max trigger voltage the 400 will handle, but you should find out what the flashes you get have. Some are pretty high voltage.
http://www.botzilla.co​m/photo/strobeVolts.ht​ml (external link)
Q2: Hooking up 3 flashes (hypothetical)
840 views & 0 likes for this thread, 3 members have posted to it.
silly question
1545 guests, 187 members online
