Thread started 28 Apr 2008 (Monday) 00:53
Batteries DO make a difference - test results
BobsYourUncle
Apr 28, 2008 00:53 |  #1
After recently picking up a used 380EX off Craigslist, My new set of standard Duracells did not take very long before the recovery time was getting excessive.
During a big family gathering today, I missed a few good shots waiting for the flash to recharge. It was getting up around 15 seconds, and the batteries have only been in there for a few days and maybe a hundred pictures or so.
So I have spent a few hours in here, searching, reading posts about batteries and studying what all of you have found.
Based on what I read here, I decided to go buy a set of Duracell rechargeable 2000mah precharged NiMH batteries.
I plugged them in tonight and all I can say is WOW!!! What a difference.
I got a timer out and ran a test on full power. With a fresh set of Duracell alkaline batteries, it took about 5.9 seconds to recycle. I pulled those out and tried my new Duracell rechargeables. Under exactly the same conditions, the recovery time was about 4.3 seconds, or about one and a half seconds less. I'm impressed!
It was really hard to resist my own feelings and get the older style 2690 mah rechargeables as opposed to the 2000 mah ones I bought, but I listened to you guys and did what was recommended.
What puzzles me is that these batteries are only 1.2 volts instead of 1.5 to 1.6 the standard Duracells are.
Just thought I would share my findings and verify that the tests done here by others are very accurate.
Thanks, guys!! :D
Set Goals!! If you aim at nothing, you will hit it every time!
EOS 70D
G1X .... and this other stuff
G11 and
380EX & 430EX
G9 - DEAD (self destructed) I'll fix it one day!
Analog6
Apr 28, 2008 00:57 |  #2
Interesting, isn't it. You'd assume (there's that word!) the stronger ones would be better. Maybe they are too much power and it takes longer adjusting or processing or something.
Odille
My Facebook (external link) / Photo Blog (external link) / RedBubble shop (external link) / My Calendars (external link)
DocFrankenstein
Joined Apr 2004
Apr 28, 2008 00:57 |  #3
Yes.
I tried using duracells once, on a job when I didn't have anything else. It's a waste of money and NiMH work much better.
I save duracells for different applications, where you need low current and you don't want them to go bad fast. I have one in my lightmeter and it works fine.
National Sarcasm Society. Like we need your support.
steveathome
Apr 28, 2008 01:05 |  #4
BobsYourUncle wrote in post #5418040 (external link)
I understand rechargeables have a lower internal resistance, and so can produce more current when needed.
Col_M
Apr 28, 2008 05:46 |  #5
steveathome wrote in post #5418100 (external link)
Yes, rechargeables perform much better than alkalines in high drain situations.
Some info on it here http://www.greenbatter​ies.com/batterymyths.h​tml (external link)
Col (short for Colin)
5D+Grip¦24-70L¦50 1.4¦100 2.8 Macro¦Sigma 70-200 EX DG¦430EX
SolidxSnake
Apr 28, 2008 06:06 |  #6
Internal resistance is the answer. The lower internal resistance, the faster the recharge. The higher the mAh, the longer the batteries last before they are dead/need to be recharged.
Troubleshooting 101 (see also: LightRules,perryge):
1) RTFM.
2) Repeat Step 1.
Gear ~ DeviantART (external link) ~ My Heatware (external link)
keegsmeister
Apr 28, 2008 06:19 |  #7
Hmm I've said that I will go down to the local shops to get me some Energizer NiMH rechargable batteries...but they go down for $20 for 4 AA batteries...I can get 8 of them on eBay for that price!
Still bargain hunting on eBay for a good set of Energizers...maybe I should look at Duracell instead :)
Keegan.
5DMK2+50D | 70-200mm f/2.8L and f/4L IS USM | 24-70mm f/2.8L | 17-40mm f4L | Canon 50mm f/1.4 | Sigma 15mm f/2.8 fisheye | 580EX2 | 430EX |
http://www.keeganwong.​com/blog (external link)
Shooting
Apr 28, 2008 08:06 as a reply to  @ keegsmeister's post |  #8
Or spend your money on a power pack and you are good for over 1,000 flashes, at least I am and I only recharge it about once a month..it is good for all my shooting all month long.
BobsYourUncle
Apr 28, 2008 09:33 |  #9
keegsmeister wrote in post #5418877 (external link)
The information I read from other threads here indicated that the Duracells out-performed the Energizers. I didn't try it myself, I just read it here from others who did.
EOS 70D
G11 and
380EX & 430EX
PhotosGuy
Moderator
Joined Feb 2004
Apr 28, 2008 09:50 |  #10
I've had good luck with the Powerex 2500 mAh niMH ones, but they're a tiny bit fatter than the other batteries. I just peeled off the label.
http://thomas-distributing.com …echargeable_bat​teries.php (external link)
http://thomas-distributing.com …-nimh-battery-charger.htm (external link)
SolidxSnake
Apr 28, 2008 14:04 |  #11
I just got in 8 Eneloops along with a BC-900 charger, grand total $63.something with shipping from www.thomasdistributing​.com (external link).
1) RTFM.
2) Repeat Step 1.
1,615 views & 0 likes for this thread
Latest registered member is ajtype
759 guests, 347 members online
