Thread started 28 Apr 2008 (Monday) 15:30
Canon S5 IS Memory card choice- SD or SDHC?..
mypoppy31
Apr 28, 2008 15:30 |  #1
I'm about to buy the Canon S5 IS digital camera and I want to make sure I buy the
correct memory card for that camera.
I intend to shoot both photos and movies with it, and that's really why I've decided to buy this camera. The camera takes an SDHC card and also an SD card. I don't know the difference between these two cards and I can only guess that perhaps the SDHC card is the better of the two?...and, is a "high speed card" preferable?...
And, since I do create a lot of photo-slideshows that last no more than 5 to 7 minutes, I can probably fit it onto a 1 Gig card?... The disadvantage of putting the whole shoot onto a 4 gig card is that what if the card should malfunction?.....I know it all depends on how long of a time I'm gonna shoot, but as I said, between the photos and video, it would be no longer than the 5 to 7 minutes....
And, is the SDHC the better card than the SD?....I've thought of buying two 2 gig cards also. But I do need advice at to which is the better card, SDHC or SD?
I'd appreciate any recommendations..
Thanks,
mypoppy31
Jon
Joined Jun 2004
Apr 28, 2008 15:35 |  #2
The SD specification is limited to cards of up to 2 GB capacity. Beyond 2 GB the standard is the SDHC (for High Capacity). Either will be fine. 9 minutes of video at 640x480x30 frames/sec (roughly TV video quality) occupies about 1 GB of space.
As for creating photo-slideshows, if you mean computer-processing the photos to add transitions and the like, you won't be able to play those back from the camera.
Jon
Cocker Spaniels
SimpleGirl2008
Apr 30, 2008 08:21 |  #3
I have a 2gig SD in mine right now.
bayoubooger
Joined Feb 2006
May 03, 2008 17:08 as a reply to  @ SimpleGirl2008's post |  #4
from what i've read the S5 fills up a card in video at ??? a Minute and turns off at 4GB max, did I miss something? oops, my bad 30-40 mins.
:lol:"The chief enemy of creativity is good taste." Picasso
S5 IS and a few options, still reading.
Jon
Joined Jun 2004
May 03, 2008 19:07 |  #5
It turns off at 4 GB, but 640x480x30 fps, the S5 max. quality, should do about 9 min/GB, which is what I see on my A620. At lower resolutions you should get up to 60 min.
Jon
Cocker Spaniels
SimpleGirl2008
May 03, 2008 19:39 |  #6
So how much video can be done with the S5 IS? 60 minutes?
Jon
Joined Jun 2004
May 03, 2008 19:43 |  #7
A 4 GB filesize limit would be 36 min. or so. But that's per clip.
Jon
Cocker Spaniels
SimpleGirl2008
May 03, 2008 20:14 |  #8
Jon wrote in post #5455075 (external link)
per clip?
I mean if you want to record like someone....doing a sport or something like that for like an hour, are you saying you cant?
Jon
Joined Jun 2004
May 04, 2008 08:54 |  #9
The camera will stop recording after 36 min. Of course, if you find a break in the action before then, you can start the clock ticking again. I can't think of too many sports where the participant goes non-stop for 36 minutes without any kind of interruption (out-of-bounds, penalty, change side, coach conference, injury). But if you really need an hour or more, uninterrupted by anything, you really should consider a video camera, or record at a lower resolution.
Jon
Cocker Spaniels
SimpleGirl2008
May 04, 2008 22:04 |  #10
Jon wrote in post #5457722 (external link)
I wish it would record for longer than what everyone is saying. Now that annoys me my point and shoot cybershot records for longer time. That annoys me..
Mrs. ­ G.
May 05, 2008 11:00 |  #11
SimpleGirl2008 wrote in post #5461473 (external link)
From what I have read so far - it appears the limit is taken away with the CHDK Hack for the S5. It will just record until your card fills up.
SimpleGirl2008
May 05, 2008 11:38 |  #12
Mrs. G. wrote in post #5464186 (external link)
Do you happen to have a link for that hack by chance?
Mrs. ­ G.
May 06, 2008 07:45 as a reply to  @ SimpleGirl2008's post |  #13
Here is a link to an >earlier thread on the subject<. You should find what you are looking for in there. ;)
8,946 views & 0 likes for this thread, 5 members have posted to it.
2212 guests, 127 members online
