Thread started 29 Apr 2008 (Tuesday) 01:08
S3 IS problem with bright colors
TMStare
Apr 29, 2008 01:08 |  #1
Hello. I purchased an S3 this winter and have just now really used it outdoors. I'm having a little trouble with bright colors on a sunny day. They seem to look overexposed and blurred. For instance, my wife was taking pictures of her mother's tulips (in auto mode) and everything looks pretty clear except for the flowers themselves. I tried to take pictures of some buttercups in the front yard and had similar results. I am completely new to photography but I thought that auto mode should work fine outdoors in the sun. Have any of you S3 owners out there had similar problems, or do you think there could be something wrong with mine?
Jim ­ G
I feel thoroughly satisfied
Joined Jun 2005
Apr 29, 2008 01:16 |  #2
Post some examples? You might be shooting in scenes where there's too much variation in light levels for the dynamic range of the camera's sensor...
Gear Listhttp://www.codastudios​.com.au (external link) Reviews & Hotlinks: Domke F-3x - Pelican 1510/1514 (external link) & 1610/1614 (external link) - DIY Variable Length OC-E3 - Crumpler 6 Million Dollar Home (external link) - FA-100 (external link)
TMStare
Apr 29, 2008 01:28 |  #3
Here is another example.
bayoubooger
Joined Feb 2006
Apr 29, 2008 07:31 as a reply to  @ TMStare's post |  #4
change your Auto Focus to center weighted. Anything in the greenbox gets priority focus. If you hold the shutter and focus in the box, you can rearrange the photo if you need and it will still have focus on the flower.
:lol:"The chief enemy of creativity is good taste." Picasso
S5 IS and a few options, still reading.
new_user
Apr 30, 2008 03:52 |  #5
Agreed. Focus on both pictures are on the grass instead of flowers.
New to XTI Jan-2008
Kit lens.
TMStare
Apr 30, 2008 21:04 |  #6
Thanks for the comments. I'm glad it's bad photography instead of a bad camera :)
peterpogi2006
May 06, 2008 23:34 |  #7
i have noticed that my s3 has a problem with bright yellow.. it seems to tone-down the yellow & give the rest of the image a blueish tint!! if i save the same image in RAW (using the hack) the pictures turn out a bit under exposed, but the yellow is bright & there is no blueish tint in the rest of the image. even i use different wb settings, it comes out the same!!!
in your case though, i think its a focusing problem coz the center of your pix is in focus!!
SimpleGirl2008
May 07, 2008 11:47 |  #8
That appears to be a focus problem in my opinion.
ceriltheblade
May 13, 2008 05:25 |  #9
i have had a similar phenomenon on flowers in which a deep bright red, yellow or white can often have the small intricacies missed - i.e the borders of each petal from the next. I have found that it has in part to do with direct hard sun (i live in the desert!), and when I played with the green/red/blue vibrant settings (not available on auto setting), I got better definition. When I get home, I can try to attach some examples.
7D/5dIII
50 1.8 II, MP-E65, 85 II, 100 IS
8-15 FE, 10-22, 16-35 IS, 24-105, 70-200 f4IS, 100-400 ii, tamron 28-75 2.8
600 ex-rt, 055xproB/488rc2/Sirui k40x, kenko extens tubes
2,209 views & 0 likes for this thread, 7 members have posted to it.
2230 guests, 128 members online
