Wekiva wrote in post #5426832
Oh well...I thought if the 890 had a larger sensor and less MP that the image would be better. I know that the larger sensor gives the 950 more MP but does it also provide better images? I've always heard that the reason the DLSRs had such great images for the same MP over the point/shoots was that the sensor was larger.
I just can't find info out there about the 890...guess it's too new. I can't find a single review anywhere. You would think Canon would have released the camera to a few people to do reviews on for those of us interested in the camera.
Thanks again Jon.
I haven't used either, but if I was bettin', I'd say the IQ between the two is probably not terribly different. I would focus more on zoom, wide angle, shutter speed and MP (for cropping). The SDs are all starting to look the same!
I see the SDs as 3 basic types: wide angle with 4X zoom (800 and 870), 5X zoom (new to Canon -- that's the 890) and everything else (about 3X zoom, starting at 35mm wide, there abouts). The 950 has the larger, higher MP sensor, so the IQ might be marginally better, but it won't be like the G9, because the lens is so small, and I've read the edges are fuzzy, like in all the SDs.
I've just got the Panasonic TZ5 as a replacement candidate for my SD800 (like the wide angle, but not enough zoom). The TZ5 is bigger in physical size, but does wide angle to 10X zoom, and the corners of the image are cleaner. 9MP and a 1/2.33" sensor, so IQ should be comparable to the SDs, though Pannys have more NR in camera, so the IQ out of the camera is a tweak less than Canon's. I'm testing now, to see if I'm comfortable replacing my SD. The TZ5 on Amazon is $280 at this moment. My G9 is producing better images than the TZ5, but I think the TZ5 is proving just as good (and more versatile) than the Canon. Hopefully, this'll kick Canon in the bottom, and get them going on more zoom in the SD series, but still w/WA.
6D: 50, 85, 28-75, 70-210USM, 430EXii.
EOS-M: 22, 18-55
