I'm not sure where to post this question, so, if necessary, please move it to the appropriate forum.
I have a large (2,000) picture file in which each picture's name is similar to this example:
Does anyone have a suggestion as to how I can strip the _MG_4530 part off of the name, leaving the picture to be called Johnson, Alex house.JPG? That way, I can alphabetize the files and find them more quickly.
Eventually, the names will be part of a database used by novices unfamiliar with PS and such, so adding the info to the metadata tags doesn't seem to be the answer.
I know that I can manually rename each file. I've been doing that
, but I wonder if someone has a more efficient way.
Thanks.
Mike
& digiscope with a Fuji A800
