Thread started 29 Apr 2008 (Tuesday) 20:00
Help please!
StarJack
Apr 29, 2008 20:00 |  #1
So walking out the front door I hear a hawk screech and see him in the top of a tree. Run for the camera, stick on the 70-300 DO, knowing time is short I just switch to Program AE, select the center AF point, half press, get an immediate focus lock and get one horribly focused picture!
(These are links to original large/fine so the file is huge!)
http://www.flickr.com …6@N06/245251696​9/sizes/o/ (external link)
I could tell just from the LCD things weren't right so I tried again
http://www.flickr.com …6@N06/245252065​5/sizes/o/ (external link)
This shot looked the same, the bird fluffed it's wings so I think it's about to fly, I switch to sports mode (for ai servo) and fire off 3 shots. Now I don't expect these to be great (given the branches) since sports mode selects all AF's, and they're not, but they're in better focus than the shots I pasted the center AF point on the bird!
http://www.flickr.com …6@N06/245335301​6/sizes/o/ (external link)
Or in the last shot before he flew (in Program AE again) when I put the center AF on the branch just in front of him.
http://www.flickr.com …6@N06/245252812​9/sizes/o/ (external link)
I know I'm a rookie but I can usually figure out where I went wrong with a shot after the fact. I didn't expect a great shot but I expect the area I cover with the center AF to be sharper than this. Am I expecting too much from program mode? From this lens? Can you even tell where the camera actually focused? You can check in ZB that I nailed the bird, or in the last shot the branch he's inches from, with the center AF point. I'm just lost here, disappointed and frustrated and looking for some guidance.
Regards,
Steve
LeuceDeuce
Apr 29, 2008 20:10 |  #2
Unfortunately the branches around the hawk had a higher contrast so that's what your AF focused on.
The only way to guarantee a nice clean shot with surroundings like this (cages, a lot of branches, heavy bush) is to switch to manual focus and do it yourself. I've missed way too many nature shots because the surroundings were higher contrast than the subject.
Manual focus in these situations has greatly improved my success rate. Switching your AF start to the * button will allow you to use manual focus even when your lens isn't set for it because pressing the shutter won't trigger the focus to start.
my website: Light & Shadow (external link)
my flickr (external link)
StarJack
Apr 29, 2008 20:32 as a reply to  @ LeuceDeuce's post |  #3
Since I knew from the LCD the first shot stunk I tweaked the manual focus ring before taking the 2nd shot, but the bird was just too far away for me to tell if I was doing any better than AF. I saw what you're saying about the contrast, but it appears to me the focus is no where near the center AF point. Even if it had focused on the branch in front of the bird he would be in much better focus.
Check out this shot from a similar situation when I had a 20D, but much better focus with the same lens in full auto.
http://www.flickr.com …6@N06/245270715​3/sizes/o/ (external link)
http://www.flickr.com …6@N06/245353411​2/sizes/o/ (external link)
Thank you for taking the time to look and comment!
Regards,
Steve
joedlh
Gallery: 52 photos
Location: Long Island, NY, N. America, Sol III, Orion Spur, Milky Way, Local Group, Virgo Cluster, Laniakea.
Apr 30, 2008 16:19 |  #4
It looks like you've got some movement blur in this shot as well as the camera picking the distant leaves for the focus. Also the 70-300 is reported to be soft beyond 200mm.
I've been in similar situations where I've rushed the shot, hoping that the camera will be kind to me. It usually isn't.
May I recommend that you not put full resolution shots on the web? It makes it easy for somebody to take and use without your permission. A low resolution shot has less utility.
Joe
Gear: Kodak Instamatic, Polaroid Swinger. Oh you meant gear now. :rolleyes:
http://photo.joedlh.ne​t (external link)
Editing ok
Flo
Gimmie Some Lovin
Apr 30, 2008 16:22 as a reply to  @ joedlh's post |  #5
Full sized photos are far too time consuming!
lbcyalater
Gallery: 6 photos
Apr 30, 2008 18:51 |  #6
Flo wrote in post #5436134 (external link)
agreed, resize then repost
The Gear:
Canon 6D
Canon 17-40L :: Nifty Fifty :: Canon 85 1.8
580 EX II
http://lbcyalater.zenf​olio.com/ (external link)
javaprog
May 01, 2008 09:12 |  #7
The resizes are there, click one of the links at the top.
If you go to the top left "Back to flickr photo page" you can see the EXIF data under more properties; which is 1/500th, f8, iso400, 300mm on a 40d on the shots that I looked at.
That first shot is perplexing... it looks like it focused well behind the bird. It also looks like there's some motion blur, but there shouldn't be with those settings and the IS lens. Honestly, I can't tell what went wrong.
I guess if I were to give advise I'd say shoot it two or three times. Each time if you feel the lens focus ring move shoot it again. Move the focal point around and shoot again. It's digital, you're not burning film. Although, for something like a hawk I'd burn a few slices of silver anyway :)
Oh and don't get discouraged, wildlife photography is just hard... very hard ;)
400D, Sigma 24-60 f2.8 EX DG, EF 70-200 f4L
Flo
Gimmie Some Lovin
May 01, 2008 09:42 |  #8
javaprog wrote in post #5439943 (external link)
=javaprog;5439943]The resizes are there, click one of the links at the top.
9 out of 10 times folks don't go to links....they want to see the photo posted;)
You said yourself you were in a hurry, so the time it would have taken to set your subject wasn't there?
LD said it well.;)
poloman
May 01, 2008 20:05 |  #9
Motion blur is a major problem in this shot. You are shooting at 300mm freehand and in a hurry. If you want to bird, you will probably want a different lens. I had a 75 to 300mm Canon and had some decent shots but paid in time to get them. Move to some long focal length L glasss and you will be assured of much better results. If you can use a tripod, it will dramatically improve your results.
"All those who believe in psychokinesis, raise my right hand!" Steven Wright
StarJack
May 02, 2008 07:05 as a reply to  @ poloman's post |  #10
Thanks for the comments. Flickr allows you to choose which size to look at, I left these full size so you could tell just how terribly out of focus they were, I won't do that again. :oops:
I leaned against the wall and tucked my elbows in, and with the IS and the light I didn't expect any motion issues. Time was short, a little less than 3 minutes and I spent a bit of that looking in frustration at the LCD. I'm not birding per se this was just a (missed) opportunity shot. In retrospect I wish I had grabbed the tripod, since I didn't get the shot anyway.
The shots with the 20D in the 2nd post were taken standing freestyle in the backyard and while the subject didn't cooperate like this hawk, at least the pictures were sharper. I know I'm in the 'consciously incompetent' phase but I have stepped up my reading and am gradually making more time for shooting. Still, my focus failure rate with the 40D with all my lenses is 2-3 times higher than it was with the 20D, though usually not so dramatically. :confused:
My sincere thanks for the feedback. :cool:
Regards,
Steve
StarJack
May 02, 2008 07:07 |  #11
joedlh wrote in post #5436119 (external link)
I hear you, but I figure with these the worst someone will do is use them as an example of how not to do photography! :lol:
Regards,
Steve
javaprog
May 02, 2008 09:13 |  #12
StarJack wrote in post #5445948 (external link)
I hate feeling like my equipment is not functioning properly :mad:
Maybe you should get it checked out. Have you tried a focus test?
http://focustestchart.​com/chart.html (external link)
(try to ignore the Nikon references, it works for Canons too :eek:)
1,758 views & 0 likes for this thread, 7 members have posted to it.
Help please!
1065 guests, 115 members online
